What an improvement!
Old Jan 3, 2012 | 02:19 AM
Hifirush's Avatar
Default What an improvement!
I finally got around to putting on my Rock Krawler High Clearance LCA's and what an improvement! I was completely happy with my lift (TF 2.5) and the way it drove. It would get a little touchy and in a crosswind it was a bit of a chore to drive it. Now, it is almost as if there is no lift. Straight and true and without any effort. I adjusted them to 23 1/8" and it is just right. Installation was simple and took about an hour, and that is because I was looking for tools (jack stands......). My son helped lining up front bolt while I adjusted the axle to where it needed to be and that was it!
One thing I continue to be amazed by, is the different in quality of stock parts and aftermarket parts. These are probably 50% heavier, beefier for sure and nicely finished. Well worth the effort and money!
Old Jan 3, 2012 | 03:05 AM
Quentin_T's Avatar
I found the same thing, basically I didn't know what I was missing with those adjustable LCA's as well. Really made the Jeep feel like stock again.
Old Jan 3, 2012 | 04:03 AM
brc450's Avatar
Did you do front and rear? Im looking to get rid of the twitch as well.
Old Jan 3, 2012 | 09:13 AM
Hifirush's Avatar
I know you asked the other poster, but I did front LCA's, it really feels like stock again, no twitchiness.
Old Jan 3, 2012 | 09:38 AM
brc450's Avatar
Thanks, looks like im gonna have to crack the wallet again....l
Old Jan 3, 2012 | 09:59 AM
mjones's Avatar
Same lift and the same distance - 23 1/8.. works great and wow a night and day difference. You only needed front LCA's set to approx 23-23 3/8. I have read some offset the length due to help with pulling to the right.. Only difference is TF vs RK..
Old Jan 3, 2012 | 03:34 PM
ricksjeep10's Avatar
Guess I'm gonna have to put these on my list.
Old Jan 3, 2012 | 04:27 PM
Quentin_T's Avatar
Same here, front only.
Old Jan 4, 2012 | 06:34 AM
Hifirush's Avatar
I don’t think it really matters what brand, well, make sure it is reputable..., but it is a noticeable difference! I read here that some guys have them set from 22 7/8 to 23 5/8. According to RK, they recommended to start at 23 1/8 which turned out to be right on. I tried it a little less (one turn) and it just seemed better at 23 1/8”. Take the time to give each a try and of course follow what the manufacturer suggests. Of course you can also listen to all of us here
Old Jan 4, 2012 | 10:51 AM
Hifirush's Avatar
Originally Posted by mpkelley20
I have the 3.5" X Factor sitting in my garage waiting to be installed but its going to be a little while before I have the time. Maybe I should install just my lower fronts to help with my driveability. Currently running the TF 2.5" so I can just use your measurements. Hmmm...
It really will! Of course, you are probably really going to the like the 3.5" X Factor
