Wheel offsets
Old Nov 26, 2011 | 09:02 PM
jknit's Avatar
Default Wheel offsets
It's bought 37 inch trail grapplers I have a 4 inch lift and 1.5 inch spacers I don't. Really understand offsets. I am looking at 17 inch fuel kranks and 17 inch fuel boosts but I want to make sure I get the right offset, they come in -12 and +14, will both fit, will both clear my brakes? Which will push the tires out further, does the offset effect the size of the lip ( i like the deep dish look of the kranks and would like a wider stance ) thanks in advance for your help
Tyler
Old Nov 26, 2011 | 09:11 PM
ronjenx's Avatar
Tyler
Here's a little information on offset and back space: (The more knowledgeable folks can explain how it applies to your situation.)
Old Nov 26, 2011 | 10:35 PM
nthinuf's Avatar
Do the math a couple times, it gets a bit easier to understand.
https://www.jk-forum.com/forums/show...do-they-relate
And 15's are the ones that have caliper clearance issues. No worries with 17's.
Old Nov 26, 2011 | 10:44 PM
Perkalater79's Avatar
These are some fascinating calculations. I spent hours researching, trying to figure out my set up in hope I would have no rubbing. And all I was doing was wheels and tires.
Old Nov 28, 2011 | 03:02 PM
Discount Tire's Avatar
Sponsoring Vendor
To clear 37x12.50-17 tires on the JK (assuming you have enough lift) you need 4.5 inches of backspace or less. The Boost and Krank are produced in size 17x9 with a -12mm offset which gives you 4.5" of backspace
Old Nov 28, 2011 | 03:24 PM
JK-Ford's Avatar
I keep this website in my favs.
http://www.rimsntires.com/specs.jsp
Old Nov 28, 2011 | 03:54 PM
OutlawJK's Avatar
So a 17x8.5 with a -12 off set with a 4.25 backspace should work fine?
Can you price me a set of 5
Of V-tec Wizards with optional centercaps delivered to 88210
Sent from my iPhone
