wheel spacers safe?
Old Feb 8, 2015 | 10:13 AM
theONLYbigHEAD's Avatar
Default wheel spacers safe?
Forgive me if there is a thread regarding this, I searched and could not find it. But has anyone used wheel spacers? I am getting ready to lift my 07 Sahara Unlimited with a 2.5 lift and 35s. Is it safe and effective to keep my stock wheels and use a wheel spacer? If so, what are the disadvantages, if any, with going this route, rather than buying new wheels. I'm looking at going 35x12.5x17 with a 2.5" lift, and yes I will be doing gears as well with the bigger tires.
Thanks in advance for sharing your knowlegde.
Old Feb 8, 2015 | 10:20 AM
Punisher's Avatar
Im running 1.5" spacers with 37's on stock wheels with no problem, just make sure they are tight and check them regularly
Old Feb 8, 2015 | 10:48 AM
Right on. Thanks Punisher
Old Feb 8, 2015 | 10:56 AM
WHT_JKUR's Avatar
Originally Posted by theONLYbigHEAD
Forgive me if there is a thread regarding this, I searched and could not find it. But has anyone used wheel spacers? I am getting ready to lift my 07 Sahara Unlimited with a 2.5 lift and 35s. Is it safe and effective to keep my stock wheels and use a wheel spacer? If so, what are the disadvantages, if any, with going this route, rather than buying new wheels. I'm looking at going 35x12.5x17 with a 2.5" lift, and yes I will be doing gears as well with the bigger tires. Thanks in advance for sharing your knowlegde.
Read a lot in this and not personally a fan of the spacers, and I really wanted to be. I don't like having 2 torque points. If you do by them, don't get the cheap ones. Go with spider trax. At that point you will be in for $200-250 (total)
Old Feb 8, 2015 | 11:03 AM
dtcercado's Avatar
Just like punisher said torque them and check them often. I put a torque stripe straight down the nut and bolt so if it does loosen I can tell. Haven't had one come loose yet.
Old Feb 8, 2015 | 11:06 AM
nthinuf's Avatar
Posts #9 and #38 give actual data from metallurgical testing of a few mfg's spacers.
https://www.jk-forum.com/forums/modi...safety-130315/
A public service message for proper maintenance.
https://www.jk-forum.com/forums/modi...ue-duh-304598/
A guy tracking down his maintenance problem.
https://www.jk-forum.com/forums/modi...roblem-291732/
So the moral of the story is to get quality components, install them properly, and then remember to actually maintain them.
Old Feb 8, 2015 | 11:21 AM
Dlampe's Avatar
Follow that advice and you will be fine. We have run them on Jeeps and race cars without a single incident. A good spacer is probably stronger than the wheel!
Old Feb 8, 2015 | 12:36 PM
Blacksahara2011's Avatar
I've had mine on for over a year without any problems. I re-torqued after 100 miles and then again every 5000 when I rotate my tires. None have loosened yet. I went with spider trax and after reading a few threads I'm glad I did. You should be fine as long as they are maintained like anything else
Old Feb 8, 2015 | 12:51 PM
dewey7015's Avatar
I have run with the Allpro spacers.....$88 for all 4. I used blue locktite, and checked them after the first 1000 miles. I like the look, and also like the look of stock wheels. I rotate my tires every 7500 miles. I will throw the torque wrench on them, set to 85#, just to check them...
Old Feb 8, 2015 | 01:24 PM
TheDirtman's Avatar
I would not run wheel spacers. Wheel adapters are what you want and properly installed and torqued will be fine.
