Wheels/Tires Advice
Old Feb 19, 2009 | 06:55 PM
seabearcaptain's Avatar
Default Wheels/Tires Advice
How big of tire/wheel combination can I go with on a stock JK Sahara? I do not want to lift it as of yet, but I also do not want to go wrong. I have seen a few JK's running around that look great with nice wheels, and meaty tires, but all have a lift. The dealer said I can go with 33's on 18's. Any thoughts? I trust you guys more than the dealer! Any help is greatly appreciated.
Old Feb 19, 2009 | 07:00 PM
Try a 285/65R18 in a Nitto or BFG a/t. Should fit with no lift or wheel spacers. They'll run close to 33" but still work on the stock wheels.
Old Feb 19, 2009 | 07:10 PM
Calypso's Avatar
I ran 33x11.5 on stock suspension before my lift but I also had wheels with 4.5 backspace. I didn't have any rubbing issues until I got into flex. So, if you have wheelin in mind you will need a lift.
Old Feb 19, 2009 | 07:40 PM
MrLuminosity's Avatar
It sounds like you like the meaty look of the tires... Go with a MUD tire.. 33s OK on stock... But I'd say - stay way from changing your rims to 18" (Changing em is great but stick to 17" rims) - you really loose tire options.... less options mean you must pay more for what you want...
Toyo has great MUD tires that do not make alot of noise... I love mine... they're 35s... I added a 2" lift... And later after you've updated your rims and worn through your 33s - and are ready for a lift.. your rims at 17" are still great providing you numerous options of available tires at the size to are going to....
Have fun out there!
Old Feb 19, 2009 | 07:45 PM
Calypso's Avatar
Sounded like he was planning on using stock rims.
He has a Sahara. They have 18" rims.
Old Feb 20, 2009 | 06:25 AM
Sorry guys, I should have mentioned that I was looking at changing the wheels also. If 17's are the way to go with larger tires, but still do not need to lift, thats the way I need to go for now. I don't plan on doing any serious off-roading, due to lack of experience for now. I am looking more for the clean, but dangerous look of larger tires than stock. Smaller wheel, larger tire?
