Who is running the Sprintex SC?
#441
first day of install didnt go too bad. i ripped a spark plug wire boot, so i will have a pick one up in the morning. i also am going to pick up a new bolt for the pulley. the bolt that came with kit appears to be too long. it bottoms out in block with a half an inch to go.
so about 6 hours today and i am guessing 4 hours tomorrow.
i am ready to get this thing out and see if it going to be worth the $ and time.
#442
Did you install the bolts the right way like I described back somewhere between page 13-16? One is longer than the other and the threaded one is the longest and goes through the pully wheel.
#443
I am using the correct bolts, the long threaded bolt just seems to bottom in the block with a half an inch left to go.
I dont think my plugs had been changed at 70k miles. They looked pretty bad.
Well......off to the autoparts store.
#444
Deli152 hope you got your install all figured out!
I just got back from a good trip on the highway (60mph and 2000rpm) and netted 20.5mpg avg with the 3.1 tune extremely happy with this and Jon has worked his magic! just around town I'm avg 16.8mpg keeping my shifts before 3000 and trying to hold 1500 around town as a cruise speed. I believe the diablo tunes have now become almost perfect! Everything is smooth and feels good, when I need too I can push my jeep and not be bogged down. This is especially important going up to the ski hill of an avg of a 10% grade for 10miles! Yes it sucks back the gas but it did the same without the sc. Haha
Also I used my cruise control and it seems to be smooth now at 60mph and can avg out a tad below 20mpg on the fuel economy! I have not felt a surge at all with this tune and also when I'm crawling around at 1000rpm in 1st or 2nd I don't feel any surges at that point either. It used to be real bad as a stock motor and no tunes but now it's nice and smooth! As well speaking of smooth when I hit 3000k+ the motor doesn't sound like it wants to blow up either, it is quiet and smooth. I believe now that the 3.8l motor loves a bit of boost and will be better off in the long run!
Hope everyone has a great weekend! If you have any questions feel free to ask or pm me, I'll try to answer to the best of my knowledge!
#445
Wow that is some good mileage you are getting. Is that the display or hand figured. I am still in the 11-11.5 mpg range, that is at 70 mph and 2450 rpms. Jon is working on the tunes and we are almost there. I know it is possible just need to stay calm and keep working on it.
#446
Everything went ok today. I finished with only one issue. The large hose that goes from the SC to the passenger side valve cover ripped. It is an awkward fit. It is running though. The vacuum leak is pretty bad. I will have to see about a replacement hose on monday.
#447
#448
Still that is good, So there is still hope haha. Yeah actually the speed limit is 75 but I am trying to keep some mileage. I know I still really like the sc and it will get better.
#450
deli152, that hose is a bear to get on. I got a new hose and cut it down as the new hose is some what pliable and will help to get it on. What I did to get that bottom clamp on was use a pair of needle nose pliers and open the clamp up and then slide it into position. Just take your time and it will go on. Also were you very careful with the map sensor when you installed it? It is very easy to tear that o ring when you push it in. I did that on mine and had a vacuum leak there. Searched and searched for the leak, finally pulled it and saw the torn o ring luckily the stock one fit it and all is was well. Enjoy the new found power.
