Will I want power back & am I forgetting anything?
Will I be wanting more power? If so, where should I regain it? Regearing? CAI/Exhaust, other?
JK stock specs: 2011 2 Door Automatic Tranny with 3.73 gearing.
Coming upgrades: AEV 3.5" lift, Duratrac 315/70-17, Procomp 7069 (17x9)
Driving habits: 70% on road, 20% mixed winter driving, 10% mild off-roading. towing around 1000 miles/year (up to 2000 lbs)
PLEASE, give any suggestions! Including other parts I may want to get with the lift and tires too.
Get a Flashpaq, I just got mine and it's amazing! I threw on the 91 octane tune after giving it a tank of midgrade and it was like a new jeep on stock tires again! I can't wait to regear and see what difference that makes on top of this! Mileage went up too!
Your cheapest option will be to just turn OD Off. Plug some numbers into the chart in the modified faq's. With 3.73's, you will find that 35's with od off is roughly the same rpm at 70 as running 5.38's with od on. (divide the od on rpm by .69 to get od off).
Programmers will adjust the speedo and get the shift points back where they need to be. (no added hp/torque through tuning)
Tuners will do what the programmers do, but also add a bit of hp/touque. They claim 10-20 hp or so, which you may or may not feel. (many people are impressed with them, I sold my flashpaq and kept the procal )
CAI/Exhaust you will feel, but are fairly expensive for the gains.
Regearing doesn't add 'power', it just raises the rpm's back to a more usable range. If you can afford it, this is generally considered to be the best gains after going to bigger tires.
Supercharger/turbo/v-8 swap - if you can afford it
Everyone's needs are different. I would drive it first and go from there. You will definitely want to calibrate for the larger tires, and being that you tow, a regear will probably be the best cost effective option. As mentioned, keep the OD off, especially on the interstate.
Gear according to tire size and purchase a programmer for changes. Hot air intakes and aftermarket exhaust only lighten your wallet. Or go big and get a supercharger.
I've read almost every performance thread. In order of price, here is the collective wisdom,
1. Superchips Flashpaq (tow tune for the win!)
2. Regear
4. RIPP long-tube headers
5. Supercharger
6. Engine swap
Everything else is debatable. Some "mods" actually decrease power.
2. Regear
5. Supercharger
6. Engine swap
So many opinions! Thanks everyone! What is the average price of regearing? And would anyone recommend a particular brand, only name I'm recognizing is Superior. Also should I just get both ring and pinion sets or will I be needing to get the rebuild kit for whomever I have change these out.
I guess this would be the prime time to put lockers in too. Lol. Probably won't bother though. Not yet.
