Winch question
Old Jul 18, 2011 | 09:35 AM
  #21
j33p_freak's Avatar
Does anyone know anything about tuff stuff winches?
Old Jul 18, 2011 | 09:47 AM
  #22
Fire Wrangler's Avatar
Originally Posted by SBEII
Jeep lists the weight of a JKU Rubi at 4340 lbs. x 1.5= 6510lbs. If your Jeep is hevily loaded or outfitted with heavy bumpers and armor it would obviously weigh more. I'd imagine mine is less with no doors, top, carpet, etc. Dave over at Northridge said 8,000 was plenty for a JKU.
Look at the weight on the label on the inside of your door jam. JKU's are over 5000lbs GVW...
Old Jul 18, 2011 | 09:52 AM
  #23
JKG8R's Avatar
You take the GVW and subtract the curb weight to get the weight you can safely carry. A JKU with a hard top and doors (auto) has a curb weight of ~4,550LBS. A 2-dr is ~3,800.
Old Jul 18, 2011 | 10:07 AM
  #24
Battlefrog's Avatar
A buddy of mine had 4,000 lbs winch in the bed of his 1/2 Ton and it worked just fine for him...
Old Jul 18, 2011 | 10:13 AM
  #25
TXCheney's Avatar
I always understood the rule of thumb was 150% of vehicle weight. If JK is 3800, then 8k should be great and okay for JKU, although 10k would be better.
Specs on my 8000lb Smittybilt are exactly the same as the 10000lb model - except the synthetic rope.
Old Jul 18, 2011 | 10:41 AM
  #26
Jollydodger's Avatar
Originally Posted by hagausaf
I can see most owners getting the 9000-10500 lbs winches for a warm fuzzy but really its an overkill unless your Jeep weighs 6000-7000 lbs which is highly unlikely. I'd like to hear what you added that added another 1700-2700 lbs to your vehicles
I don't think this is accurate. I have stalled a 10500 lb winch just in mud, of course it was only 30 feet out.When pulled out to the first couple of raps then I got out ok. A heavier duty winch you will not be pulling all the cable out every time you winch, and you will have the power when you really need it. Depends on your normal situation, extra capacity and not pulling all the cable out every time doesn't qualify as overkill in my book.
Old Jul 18, 2011 | 10:43 AM
  #27
Huntphreak's Avatar
Still no Snatch block pic
Old Jul 18, 2011 | 11:35 AM
  #28
Jason_G's Avatar
Quote Originally Posted by Huntphreak View Post
Anybody got any pics of some snatch work in action !!
This is a family website, bub.
Beat me to it!
Here's a video I found on Youtube. A real snatch block, don't get your hopes up fellas.
http://www.youtube.com/watch?v=Td92wGxvujU It's just a pulley. Increases your mechanical advantage so your winch doesn't have to work as hard (or so you can move objects normally too heavy or too stuck for your winch to move). You could also use them to change your recovery angle.
Jason
Old Jul 23, 2011 | 07:17 AM
  #29
leftcoastpunk's Avatar
Tuff Stuff?? Reeks of Chinese from a mile a way. Probably pull for a while, though. Can't say nothing. I've got a chiney Promark myself!
Old Jul 23, 2011 | 08:33 AM
  #30
Mark Doiron's Avatar
Tough Stuff makes some great Jeep products. To the best of my knowledge, the only winch-related item they make is their safety thimble, which I have and love. They also make a hood-mounted Hi-Lift/shovel-axe mount: Ditto on that loving feeling. Personally, I would not patronize a business that steals the name of a good one by playing with the spelling.
As for winches, the important things are how much pulling force is required (if in mud or sand, a lot more than the weight of the Jeep), and how many line wraps are paid out. You'll lose about 40% of your pulling force if you're on the outermost wrap of a winch spool. You can make up for this by use of a snatch block.
