Wobble at 45 mph
Old Jul 30, 2013 | 04:42 PM
Ryan0260's Avatar
Did you check for stuck mud or debris on the inside of the wheels? This will definitely cause these symptoms. It honestly doesn't take much to throw them off balance.
Old Aug 2, 2013 | 04:09 PM
JKBANDIT55's Avatar
Thanks to my buddies over at Knuckles Off Road, We got the wobble all figured out!
oh and pics of the new 37s and Billies!
Old Aug 2, 2013 | 06:27 PM
kjeeper10's Avatar
Vet Army
Well... What was it ?
Old Aug 2, 2013 | 07:11 PM
Rebelyell22's Avatar
This started playing in my head when I read the title
http://www.youtube.com/watch?v=qd6UI6wEIsU
Old Aug 2, 2013 | 08:51 PM
karls's Avatar
x2.....
Sent from my Droid4 and Jkfreaks.com
Old Aug 2, 2013 | 10:08 PM
JKBANDIT55's Avatar
Well we started with the ball joints, those were good, tie rod good, took the front DS off and still had the wobble so we counted that out. Track bar good, messed around with the toe setting and got the front tires re balanced and the wobble is gone.
It doesn't make sense because the wobble started 2 weeks ago when I had 35s. Went and got them re balanced and the wobble was still there. then, a week ago i Switched to 37" MTRKevlars had those balanced and the wobble got worse. So I figured it couldn't be a balance issue. If I've had 2 balances in 2 weeks.
At discount tire this morning they said sand bags were previously used and the tires were way off balance. So they used lead weights for balancing and we adjusted the toe and now it's gone. I did feel the wobble after the toe adjustment just not as bad. Then after the balance it was gone completely.
So I'm thinking a combination of the two eliminated the problem. Either way we got it fixed and I'm pumped to wheel this Sunday!!
Old Aug 2, 2013 | 10:41 PM
37s on a stock d30??
Old Aug 2, 2013 | 11:44 PM
JKBANDIT55's Avatar
Yup. Their only 11 lbs heavier than my old 35" duratracs and the 30 has held up fine for the last year through Moab, and wheeling here I'm CO every weekend. Once it goes I can get ahold of a 44 pretty fast so well see how long it lasts. At 71 lbs that's pretty light for a 37. It's actually in the same weight category as most 35s!
Old Aug 3, 2013 | 05:42 AM
Jersey_Devil's Avatar
I ran 37"km2 tires on my 2010 Sahara and with stock gears too! (flipped and totaled now)
Old Aug 3, 2013 | 06:06 AM
sastocky's Avatar
Hijack....how do you like the kevlars for highway travel?
