Woods Steering Stabilizer Relocation Kit
Old May 26, 2010 | 11:32 AM
HG07JKRubi's Avatar
Yeah I saw the pics. I don't have any clearance issues from those angles as well...but my issue is from underneath the SS at the track bar bolt head. It's hard to see from your pics how close your SS is to that bolt with the SS fully compressed. I'll try to post a pic of the issue later tonight.
Old May 26, 2010 | 02:44 PM
HG07JKRubi's Avatar
Here's a pic of mine to show where the rubbing is occurring. This is fully turned right.
Old May 27, 2010 | 08:02 AM
69thunderbird's Avatar
Default rotate?
can you rotate the tie rod u-clamp so it doesn't rub?
Old May 27, 2010 | 12:21 PM
rinkishJK's Avatar
yea try and rotate the u clamps. ill post the same pic later. ill take a shot of mine.
Old May 27, 2010 | 12:30 PM
rinkishJK's Avatar
well i think u helped me see a problem i have. mine stops where the dirt starts. it doesnt go all the way in, so i think i need to adjust mine, and then i think ill have the same problem as u..
looks like your SS is leaking too.. no?
Old May 27, 2010 | 12:43 PM
HG07JKRubi's Avatar
Yes...it's leaking. I may just go back to my OEM SS.
According to the Woods install instructions there should be 1/8" - 1/4" of rod exposed when the wheel is fully turned to the passenger side. I think I have that right. I also have my u-clamps rotated such that the SS will not contact anything during suspension travel .. again according to the instructions. May this bracket is just not compatible with the TF SS ???
Old May 27, 2010 | 12:46 PM
rinkishJK's Avatar
maybe it isn't. i def have more than 1/8 to 1/4". mine is prob an inch or a lil more. i honsetly havent noticed it or a problem till i saw your pic. not sure if i should move mine or leave it.
it turns fully.. idk. what do u think?
urs looks like a 1/16". i think they mean the shiny part when they give the measurements.. i could be totally wrong, but if u put urs like mine i guarantee it wont hit!
Old May 27, 2010 | 12:49 PM
rinkishJK's Avatar
1 other thought i just had... maybe yours is leaking cause its in to much and is over extending it. well over extended in not out.. idk just a thought.
Old May 27, 2010 | 02:48 PM
Default Adjusted
I didn't follow woods instructions and made the "shortened" damper with aboUt 3/4" exposed rod (long enough so it didn't rub). Before I installed the damper I pulled it to "max" length and measured (think rod exposed was 6-3/4??). That way I knew when I turned left to right what the max rod exposure was.
Old May 27, 2010 | 03:09 PM
HG07JKRubi's Avatar
I may try the same thing before I revert to the OEM SS.
