Worn tires
Could tires that haven't been rotated and are oddly worn produce the effects of incorrect camber? Say the tires are more worn on the inside then on the outside of the tread. I recently rotated my tires and installed 1.5" spacers. The steering has become more flighty.
Thanks in advance.
Thanks in advance.
should get alignment after any modification to suspension or wheel ends BUT
im a hd diesel tech and big rigs have dedicated steer and drives that obviously cant be interchanged so after about 50k miles on the steers the inside edge wears away more than the outside due to the inclination of the tire while turning, so it is possible to have irregular wear with a proper alignment
Originally Posted by archijeff
What size tires? D30 axle? Lift it up, grab tire at 6-12 o'clock and check for slop... Ball joints are proned to go
