Worn tires
Old Jun 28, 2012 | 06:56 AM
williard86's Avatar
Default Worn tires
Could tires that haven't been rotated and are oddly worn produce the effects of incorrect camber? Say the tires are more worn on the inside then on the outside of the tread. I recently rotated my tires and installed 1.5" spacers. The steering has become more flighty.
Thanks in advance.
Old Jun 28, 2012 | 07:15 AM
Tippittrg's Avatar
Uneven wear on tires is usually caused by poor alignment. After putting in the spacers, you should get the alignment done. Both will affect your steering and handling.
Old Jun 28, 2012 | 07:22 AM
williard86's Avatar
Thanks..that makes since.
Old Jun 28, 2012 | 07:37 AM
bigredburns's Avatar
should get alignment after any modification to suspension or wheel ends BUT
im a hd diesel tech and big rigs have dedicated steer and drives that obviously cant be interchanged so after about 50k miles on the steers the inside edge wears away more than the outside due to the inclination of the tire while turning, so it is possible to have irregular wear with a proper alignment
Old Jun 28, 2012 | 07:41 AM
SBEII's Avatar
Depending on how wide of a tire you are running with the spacers, it may not follow the ruts in the highway and will wander some.
Old Jun 28, 2012 | 07:42 AM
archijeff's Avatar
What size tires? D30 axle? Lift it up, grab tire at 6-12 o'clock and check for slop... Ball joints are proned to go
Old Jun 28, 2012 | 07:52 AM
williard86's Avatar
315/70r17. I'll check the joints. Is there I particular motion? Like, do I move the tire vertically or twist the top out and in?
Old Jun 28, 2012 | 07:55 AM
archijeff's Avatar
Yeah, your basically checking camber. Top and bottom for real sloppy play (up and down movement)
ush the top in pull the bottom out and alternate that motion rapidly
Old Jun 28, 2012 | 07:56 AM
archijeff's Avatar
Yup, just like that
