X running 37''
Superchips Flashpaq
Teraflex steering stablizier
5.13 gears
EVO C2 Gussets
EVO 30 Magnum sealed axle sleeve
TeraFlex 4'' suspension system with 4 flex arms
Now for the tires, I think I have narrowed it down to three:
Goodyear Wrangler MT/R (favorite so far)
Toyo open country M/T
BF Goodrich KM2's
Thanks for any help
5.13 gears
EVO C2 Gussets
BF Goodrich KM2's
Thanks for any help
All an awesome choice! Id ditch the teraflex steering stabilizer if your stock one is fine. If it needs replacing then go for it.
Your D30 will be fine, get the 37's.
Dont forget driveshafts my good man. I went with coast driveshafts front and rear from Northridge. Mine were yoke style not flange (which is the way to go in my opinion).
You may want to look into track bars and track bar brackets (if not included in your kit), high steer, and extended stainless steel brake lines, quick disconnects. All of which teraflex too supplies. Just get these as upgrades as you go along, but for now get that kit yaya....
Also get the jeep aligned after you get the lift installed. This is a one time payment for a long time peace of mind.
The evo sleeves and c gussets would be one of my first upgrades after the lift bar none. Once you bend an axle tube or outer c then you are stuck with a bent one!
Nice list there! FYI TeraFlex now makes knuckle gussets ($35.99) and axle sleeves ($99.99).
http://www.teraflex.biz/products/jk-...usset-kit.html
Just courious, why?
