New to forum and have a suspension question, please help!
Old Jun 15, 2023 | 01:13 AM
JustAnotherJKU's Avatar
Originally Posted by XJRefugee
Just another - are you looking to get a whole system or kit (coils, shocks, adjustable control arms, front drive shaft) ? do you have adjustable front lower control arms now? or will you go the frankenstein method and piece it together? cheap says buy 1" spacers and shock extenders and be done with it. A lot of folks on this site like Metal Cloak , me included. There are a few more solid choices depending on how deep you want to get into it.
Will likely need coils and bump stops only, the fox shocks seem to be in good condition, and don't need rebuilding at this very moment. I am however also looking at getting the JKS adjustable lowers to make up for the added angle when I do get the new lift. I looked at metalcoak (I'm saving up for the over line kit) and their 3.5 with 6 packs is unfortunately not in the budget yet. If I dropped that kind of cash I would just weld in a coil over kit.
Old Jun 15, 2023 | 03:46 AM
XJRefugee's Avatar
You will spend more money on the bump stops than a good set of coils but that sure makes it a lot easier just going with coils. I am running rock krawler triple rate springs and have been quite pleased with them. The JKS lowers is a solid investment and will help dial in the front caster angle and help save front drive shaft.
Old Jun 15, 2023 | 06:41 AM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by Seizer
@Sixty4x4 I've tried every needle fitting I have access to get that one DC flat faced zerk. It never wants to go in and makes a mess. I just pull the shaft from the transfer case and have an assistant pump the gun while I hold my needle fitting against it. Can you please show me what needle fitting you use to get the DC? Possibly a link to where I can buy the one you are using?
I have never had an issue getting to my DC zerk with a basic Lincoln needle fitting....even with skids in place. It's tight but doable. Having front hub conversion makes it a little easier for me since i can freely spin the DS. Sixty is on MC 2.5" lift as well, like you with your 2dr, so I would think you should be able to get at it if the DS was in the right orientation.
Old Jun 15, 2023 | 07:49 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Seizer - this i what I use to grease zerks with. Bit awkward on a creeper but manage to hold it against the little ball stop in the zerk and pump at same time.
Old Jun 16, 2023 | 06:06 AM
Seizer's Avatar
That is one of the styles I have. I’ll try it again next time, but it’s like the flat zerk ball resists any pressure unless on it perfectly squared up.
Old Jun 16, 2023 | 06:14 AM
resharp001's Avatar
Loved
Community Favorite
that is what i use too, but on a flexible line. i typically go in with the head at a slight angle and slide the ball out of the way......but that's just how she likes it.
Old Jun 16, 2023 | 01:28 PM
Thank you for the suggestion on the springs I will look into those to suffice for now. I do plan on doing a weld in coilover eventually but the only person I trust to weld on my rig currently lives in Vegas and isn't moving back east until next year so that will be a save up job.
