Ft Lewis Area Mechanic
Old May 20, 2012 | 12:28 PM
207original's Avatar
Default Ft Lewis Area Mechanic
New to the area and recently developed a problem with my jeep. Ive never worked on cars before plus I have no tools to do anything anyways. I was wondering if there are any good mom and pop type garages in the area that could help figure out what was wrong with it. Don't want to go to a dealership. Ive looked online about what could be wrong with it, but there are many things it could be and i just don't have the knowledge to figure it out
Old May 20, 2012 | 12:35 PM
nwbronco's Avatar
What sort of problem? Your are here so I can guess it's an '07 or later JK/JKU. Plenty of folks on the list assist.
Bob K.
Old May 20, 2012 | 12:56 PM
Bob K.
yea its an 07 unlimited sahara. got off the highway the there day and it started sputtering, thought that maybe it was because of low fuel. got to the gas station and filled up but it still did the same thing. on my way back to base it became a lot worse (felt like the entire engine was shaking) and the check engine light came on, flashing and beeping. now it won't start unless i give it a lot of gas while turning the key, but even after that it will stall out. pulled a code of P0300 (random misfire). also, the starter will stay on until i actually turn the key off.
Old May 20, 2012 | 01:49 PM
nwbronco's Avatar
Could be coil pack, computer glitch, or timing chain. Start with the easy one. Disconnect battery for a few minutes and see if the problem goes away. If not, the a bad coil pack may be next.
There are a couple of shops down here in my area.
Bob K.
Old May 23, 2012 | 01:08 PM
metalcd's Avatar
if you really need to take it to a shop, i would suggest that you head to moose's tillicum auto tech. its a father/son shop with about 4 employee's located at a gas station right off base.
Old May 27, 2012 | 06:02 PM
Battlefrog's Avatar
Do you have and automatic or standard?
Old May 27, 2012 | 06:09 PM
Battlefrog's Avatar
Take a look at passenger side behind the tire. There is a small clip/harness there (black) that sits at an angle. It may have come out. This sounds a lot like the symptoms my buddies jeep had on the trail. I almost found it by mistake. I got it plugged back in and problem solved. Not sure if it's some type of fuel, ignition sensor etc... His jeep is also a Sahara (auto). I've never checked to see if my standard has one....
P.s., I report to first Lewis on 10 July to the 21st CTC...
Battlefrog's Avatar
Passenger front... (my bad)...
Old May 28, 2012 | 11:39 AM
ill check that out, thanks. I've been super busy so the jeep has been sitting around for almost 2 weeks. i finally have time to get it fixed.
Old May 28, 2012 | 01:37 PM
Battlefrog's Avatar
Your gonna have to go behind the plastic fender pieces to get to it.
