Which Winch??
Old Jan 24, 2010 | 07:14 AM
4x4fn's Avatar
Default Which Winch??
I am looking at getting a new winch. I have narrowed it down to the smittybilt xrc 10 and xrc 8. I have a jk unlimited by the way. The difference between the 2 is if i get the xrc 8 i will get the one with the synthetic line, the xrc 10 would not be based on price. So would I be better off with the xrc8 with synthetic line or the xrc10 for the extra power, steel ine...I May use it a few times a year but thats it.
Thanks
Chris
Old Jan 24, 2010 | 07:25 AM
Hbomb's Avatar
google titan offroad recovery gear. their shop is about 15 minutes from where i live.
Coming soon our latest models in the SABRE Range of Winches
I am not going to say too much about these Winches right now EXCEPT i don,t care what you pay or what Brand you get , It will be very hard to beat these new models in performance at whatever price.
Shown below is our introductory entry level 9.000lb Winch this winch has 10 different patents on parts / motor / controls / fairlead
and is the same basic design motor as our other 2 models including the
Sabre XD 2-speed 12.000lb that beat out all Warn ( except the 8274 ) Superwinch , T.Max, Come-up in the Winch Challenge for the Malaysian Rain Forest challenge
All the new Model Sabre Winches Feature
Fully Adjustable overload torque bolts
Electro Magnetic Brake discs for 100% brake control
( regular brakes hold the direct amount of load against them )
Our winch always holds the Maximium capacity of the rating of the Winch
Carbon Brushes extends the life of the motor by more than 2.5 times the normal lifespan due to the unique design of the guide tabs to keep constant contact and very little wear on the faces of the Brushes Due to the carbon material
Hand control monitors your battery output while winching
Magnetic base in control handle to hold it on the Hood / Vehicle
100% engagement for clutch handle every time
Fairlead rollers use Bearings for easy spinning and less drag on the line
These are just a few Features on our Introductory Winch with
to learn more just give me a call
Cheers
Name:	SABRE WINCH.jpg
Old Jan 24, 2010 | 07:48 AM
Olean NY Jeeper's Avatar
Originally Posted by ECHO
With the Unlimited I would go with the XRC-10.. Get the extra power !!
I have one on my 2-dr bought it for a good price w/synth line..
I agree, with the 4 door, you will want the power.
Old Jan 24, 2010 | 08:18 AM
4x4fn's Avatar
So go with the power not the better synthetic line. I guess that makes sense, you can always up grade to the synthetic line. Just thought that $450.00 for the xrc8 with synthetic line and free shipping would be the way to go....
Old Jan 24, 2010 | 09:01 AM
frankie945's Avatar
XRC 8. with a snatch block just in case suits me just fine. You can pick one up for 299 shipped.
Old Jan 24, 2010 | 09:03 AM
horwitzs's Avatar
Why compromise?
You can get the 10 with the synthetic line and free shipping... winchdepot.com
EDIT: oh I get it, you are getting steel on purpose with the 10 to save money, not because of availability... sorry.
Well maybe the free shipping helps with the difference.
Old Jan 24, 2010 | 10:49 AM
nangulator's Avatar
I went with the comp10 (synthetic), I got a great price on it from 4wd.com
Old Jan 24, 2010 | 11:37 AM
Sethc84's Avatar
Honestly I have the XRC8 on my 2dr and all I can say is it pulled me out when I needed it but its definitely a "value" priced item. It looks just like rugged ridge's new winch to boot. I am not saying the smittybilt winches don't work but after running this winch I will be upgrading to a Warn in the next couple months.
You can get the M8000 for $539.00, more expensive but well worth it.
I plan to stay away from smittybilt products like their bumpers, rails, and winches. Its all inexpensive imported stuff, as for their interior equipment, I'll still buy it. I don't have so much of an issue with imports, just if it is an inferior product.
I love the rear gear they make, very prctical.
Old Jan 24, 2010 | 01:45 PM
adamisadam's Avatar
get the 10 over the 8 for sure on a Unlimited. but based on what my research showed me, I'd recommend the M8000 over the Smitty 10. plus, the steel line has many advantages over synthetic depending on situations. search on my posts in the last 2 months on the subject. I even interviewed a Warn exec/engineer who gave me his 25 years of Warn input & experience. not just people saying 'Warn is best,' but actual facts & details.
then get a winch kit (including snatch block) cause u really need it.
Old Jan 24, 2010 | 03:54 PM
Heavy Metal's Avatar
I gotta recommend the Warn M8000. Only because I've used it for pulling stuff around the farm and also getting unstuck and it works now 3 years later as it did new.
