2012 exhaust/drive shaft issue
Old Jun 26, 2012 | 12:51 PM
bOLsAK=3's Avatar
Default 2012 exhaust/drive shaft issue
After doing a search about the 2012's lifted suspension exhaust/drive shaft issue I haven't found anything, so I'll ask it here. At which height of lift does the drive shaft contacting the exhaust become an issue? Also I've noticed that Rancho has a couple of fixes available for options but how about the other suspension companies? Are basic 2.5"s as far as you can go without buying a drive shaft or exhaust fitting?
Thanks for the help.
Old Jun 26, 2012 | 12:57 PM
Dirty Mick's Avatar
I have a Rough Country 3.25" lift with the v2 shocks and have zero contact with my exhaust. I've taken it wheeling a couple of times with rivet crossings, trail riding and small rock crawling and have yet to touch. The issue isn't with the lift height itself (within reason) but with the amount of travel your shocks allow at FULL droop. With my RC lift at full droop, I have roughly a half inch of clearance still.
Old Jun 26, 2012 | 12:59 PM
PATHOOJK's Avatar
HI! I've a 2012 Unlimited with a 2.5" RCX lift and i've a good clearance for the driving shaft without the exhaust speacer.
mattgt5's Avatar
O hit at full droop with 3" and 5100s. I have the TFlex spacers and still hit. No issues with the dive shaft yet and I'm not replacing till it fails. Been lifted for 8 months and almost 15k miles
Old Jun 26, 2012 | 01:03 PM
PATHOOJK's Avatar
does it hit just in extreme flex??
Old Jun 26, 2012 | 01:13 PM
rb1boxer_3's Avatar
Mine doesn't hit yet. But I have the rk 3.5" max travel and got about 6 up front and 4.5 rear.
ID:	334111   Click image for larger version
ID:	334112   Click image for larger version
ID:	334113   Click image for larger version
Old Jun 26, 2012 | 01:14 PM
keithvegas's Avatar
I have the Rancho 3" Trail with 9000xl shocks and neglected to mount the drop exhaust immediately. The first time out I tore on rib on the shaft boot most of the way around. At one point I had the driver front off the ground so that should be full droop.
I don't think the shaft could touch the pipe but it looks more like the boot got very close and melted about one inch increments with 1/2" sections of unmelted boot. The slip boot isn't really needed but since I bought the pipe already I installed it. Now my concern is that the pipe is very exposed and as far as I know there isn't a skid made to protect the crossover that low. I'm planning on getting an Adams front shaft and either having the old pipe welded back in or trying to get a cheap take off Y.
Old Jun 26, 2012 | 01:19 PM
bOLsAK=3's Avatar
OK, so here we go, and you only have a 3", huh?!
I suppose I should have also posted a question reguarding any differences with an auto or stick
Old Jun 26, 2012 | 01:49 PM
HogHoden's Avatar
As mentioned, its more about flex (droop) than lift height. I have the AEV 2.5 DS kit on an Unlimited with auto. Not exactly the most flexible kit out there, but my driveshaft boot was too close for my comfort. I opted for the Teraflex exhaust spacer kit. I figured $50 bucks now is better than $500+ later to replace the driveshaft.
Old Jun 26, 2012 | 02:10 PM
bOLsAK=3's Avatar
Well I just stumbled upon Teraflex's youtube video explaining pretty much anything I needed to know.
I highly recommend heading over to their site and click on the jk exhaust spacer kit link and check out that video!!
