AEV Rear Bumper
Old Nov 21, 2012 | 04:30 AM
Razorbak's Avatar
Default AEV Rear Bumper
I want to get this bumper but not sure if I need the one w the tire carrier or not. I currently run Nitto terra grapplers 285/75/17 w custom rim. The tires are still new but when I do get new tires I might move up to the 295/75/17 and don't want any issue w the tire/wheel weight. Can the tire carrier be added later or do I need to purchase w bumper?
Old Nov 21, 2012 | 05:13 AM
lphsl's Avatar
The tire carrier can be added later.
Old Nov 21, 2012 | 05:49 AM
foo.c's Avatar
It can, but you'll have to remove the bumper to do it.
Old Nov 21, 2012 | 06:34 AM
Andre's Avatar
If you have the $$$ to get it all now it's worth it... That way you're not messing around, taking off a bumper to add the TC down the road.
Old Nov 23, 2012 | 05:13 PM
kneeman's Avatar
The right rear tank also comes with or without a hole if you add tire Carrier or not. Something else you would have to swap out.
Old Nov 23, 2012 | 08:56 PM
Roaddog545's Avatar
The Duchess has the AEV rear bumper and a Teraflex tire carrier which looks great together. I think there is a weight savings versus the AEV carrier and the spare opens with the tailgate still. That is a big plus if you ask me.
Name:	20121014_150231 (800x600).jpg
ID:	391666Click image for larger version
Old Nov 23, 2012 | 09:24 PM
PGT's Avatar
PGT
I think I'm leaning towards the TF as well vs. adding the AEV tire carrier. Half the cost of the AEV and I like the features (mounts in the center, not offset; lower weight; one piece opening, etc)
Old Nov 26, 2012 | 03:51 AM
Razorbak's Avatar
Does the TF handle larger heavier tires and help with the weight on the hinges of the rear door? Probably the biggest tire I will go with will be 295 or 305 since I only have a 2" lift.
Also, how hard is it to install the AEV bumper?
Old Nov 26, 2012 | 04:53 AM
PGT's Avatar
PGT
Attachment 391666Attachment 391667
does that CHMSL come with the TF or is that another brand?
Old Nov 26, 2012 | 04:59 AM
Vin's Avatar
Vin
That third brake light pictured comes with the Teraflex Tire Carrier. It uses the OE brake light. I added some LEDs and used it as a license plate holder as well.
