Rotate 5th tire or not???
Old Nov 24, 2014 | 02:12 PM
shamisc's Avatar
Default Rotate 5th tire or not???
I've been tossing back and forth on this....not sure what to do! I'm pretty sure im going back with the same tires.
What do you guys do and why?
Old Nov 24, 2014 | 02:16 PM
afpilot82's Avatar
JK-Forum Ambassador
I paid for all 5, so I'm going to use all 5. Rotate regularly and extend the life of the entire set. There are numerous threads about 4 vs 5 tire rotation out there if you search a little.
Old Nov 24, 2014 | 02:25 PM
Descent's Avatar
Absolutely
No reason not to
Old Nov 24, 2014 | 02:42 PM
nthinuf's Avatar
People post ads for these spares on craigslist all the time. None of them are sticking with the same tires, and I don't really want a 'new' tire that has been rotting on the back of someones vehicle for several years. Do a five tire rotation, and if you happen to stick with that same tire, keep the best looking of the original set as a spare.
Old Nov 24, 2014 | 03:00 PM
Radguy's Avatar
Use it!
Otherwise that's one expensive spare tire!
If you're not going to use it you're better off buying a compressor and plug kit, unless you're a serious rock crawler.
Old Nov 24, 2014 | 03:15 PM
rvator's Avatar
I like using 5 for the rotation. It only takes one jack now!
Old Nov 24, 2014 | 04:16 PM
bluebear's Avatar
I reluctantly do it ...don't look forward to killing my back every time with a 37" spare.
Old Nov 24, 2014 | 04:20 PM
fultonromero12's Avatar
I suggest if you are going with the same tire then the next time you need tires you put the spare into rotation and purchase a new spare.
Old Nov 24, 2014 | 04:30 PM
kmrtnsn's Avatar
Five tire rotation, absolutely. In fact, because I play in places like the Mojave and Death Valley I am contemplating an additional, or second spare, and if I go that route I'll run a six tire rotation; spares to front, fronts to rears, rears to spares.
Old Nov 24, 2014 | 04:52 PM
Sahara Lee's Avatar
I rotate all 5. The only reason not to is if you have a donut spare... In which case, you are beyond hope.
I do the rearward cross. That is diagram "G" on this page:
http://www.tirerack.com/tires/tirete...141125014125:s
Jack right rear, swap for spare. Raise right front and swap for right rear. Raise left read and swap in front right. Raise left front put left rear on and left front goes to spare. Same amount of lifts (or less) as a 4-wheel rotation unless you let a shop do it. I don't trust shops to torque the lugs properly. In my experience typical shop torques anywhere from 60 to 120 ftlbs depending on air pressure and attitude of tech.
