rock Krawler custom legth CA's
Old Apr 23, 2015 | 03:41 AM
kjeeper10's Avatar
Vet Army
Figured I would share here on JF as well.
I see a lot on the forums people having issues moving the axle back 1" with the X-factor setup. Some people even swapping out to different arms or back to stock. The threads are actually tapped deep enough to cut them down if you have the means. I ordered mine shorter, seeing the issues around.
The rear lowers are slightly longer [than the max Travel lowers] and the uppers adjust down to stock + 1"-1 1/8 max.
I have a 2 door w/ 3.5" coils. The new rear lowers are set to 20 1/4 or 1/2 over stock. Uppers are set to around 18 1/2 which has my pinion -2°
The short arm rides amazing. With the new Pro series Flex Bushings NVH is kept to a min. Better then the stock arms and drop brackets I was running.
Kudos to Rock Krawler, I couldn't be happier. Pics below
Old Apr 23, 2015 | 03:42 AM
kjeeper10's Avatar
Vet Army
Pics one at a time lol
ID:	607734   Click image for larger version
ID:	607735   Click image for larger version
ID:	607736   Click image for larger version
ID:	607737   Click image for larger version
ID:	607739   Click image for larger version
ID:	607740   Click image for larger version
ID:	607741   Click image for larger version
ID:	607742   Click image for larger version
ID:	607744   Click image for larger version
ID:	608138   Click image for larger version
Old Apr 23, 2015 | 04:41 AM
DunnyBunny's Avatar
JK-Forum Ambassador
I haven't seen to many issues people are having. I have absolutely no issues with mine moved back an 1". Is it mainly a 2 door thing? I think I've seen some spring bowing with them.
Old Apr 23, 2015 | 04:53 AM
kjeeper10's Avatar
Vet Army
Yes, coil bowing, track bar bind, swaybar links contacting stops, UCA mounts. Shock body hitting TB bracket. Mostly a 2 door thing but easily addressed with slight modifications. Some shops, people don't follow instructions and just bolt the arms up using RK's numbers. Every jeep is a little different and most likely will need fine tuning. I have the 5/16 drill and tap to move the swaybar back a little. My coils have a slight slant but look good.
My upper arms are not set to the same lengths either. Once lowers are in I placed a jack under the diff to hold where I wanted pinion angle.
Both arms adjusted out to fit the mounts. This removes any bind, bind that might have been present with the stock arms and will prolong bushing life.
Old Apr 23, 2015 | 05:02 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Ok I was curious. I followed directions and moved swaybar back and all that so I had none of the issues. However I'm about to see how the new MC arms will affect everything. I believe they are adjusted to move it back about a half inch. Nice looking rig BTW
Old Apr 23, 2015 | 05:27 AM
kjeeper10's Avatar
Vet Army
Thanks brother. Yea the Mc Arms like most add 1/2 but can go out further if desired.
Another thing I noticed was RK's front uppers min at 19 1/4.
This forces +1/2 along with the lowers. I set them to 23 1/4 lower, 19 1/4 upper. Coils look perfect but I prob can't run Synergy's sector shaft upgrade. There's only maybe 1/4 inbetween the bracket and coil now. Prob doing Hydro assist anyways
Old Apr 23, 2015 | 05:33 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Yea I run about 23" lower and 19" upper with the MC fronts. Just need to get rears on now.
Old Apr 23, 2015 | 05:35 AM
kjeeper10's Avatar
Vet Army
You have enough caster ?
Old Apr 23, 2015 | 05:41 AM
DunnyBunny's Avatar
JK-Forum Ambassador
I should be at the same as you nearly. Mine are both shorter then yours by 1/4". I'm going to get a pic with angle finder on it and post it up. Maybe you can tell me. Haven't had alignment done yet as I'm waiting to get the rear on also. When I put the angle on the ground it reads about 89*, when on the flat round spots on the pumpkin it reads about 91*. I'll post pics though
Old Apr 23, 2015 | 05:49 AM
kjeeper10's Avatar
Vet Army
It depends on height actually.
I believe you would have to subtract that 1° ?which would put pinion at 90° (6° caster)
