Is the Dana 30 strong enough to support 35's?
Old Mar 2, 2009 | 08:42 PM
livin's Avatar
Default Is the Dana 30 strong enough to support 35's?
Will the Dana 30 be any less capable with the appropriate gearing then a Dana 44?
Thanks,
Jacob
Old Mar 2, 2009 | 08:46 PM
RedneckJeep's Avatar
With EVO gussetts, chromemoly shafts, trusses and a good locker, it will handle 35s fine. I wouldn't go any bigger, though.
Old Mar 2, 2009 | 08:49 PM
BlackNorthernJK's Avatar
x2
others are throwing them on without...but I wouldn't reccomend it, search the forum you'll find people are finding strength issues with these stock axels
Old Mar 2, 2009 | 09:10 PM
livin's Avatar
Thanks guys, I am still trying to figure out Rubi vs X... and you guys are certainly helping me figure it out.
Seems like I just need to take a hit and pay the bigger bucks for the Rubicon... I hope to have this jeep for a long time, and I will be lifting it and putting bigger tires on.. I will end up regearing it... and though I probably won't be rockcrawling.... I do drive really hard, and I like to do doughnuts, and fishtail in the snow and mud, gravel etc...
thanks again,
Jacob
Old Mar 3, 2009 | 12:26 AM
SGT.'s Avatar
I have been running 35's on my stock 30 with 5.13's and a locker for about a year now without any problems, bending breaking. I would not go 37's though.
Now I just went to Offroad Evolution and had then weld the gussests and skids to give it some strength just in case.
I will also be up grading to CM shafts soon, but so far so good.
Again one year with stock shafts and some hard wheeling without a problem....
Old Mar 3, 2009 | 04:39 PM
livin...just check this out https://www.jk-forum.com/forums/stock-jk-tech-12/front-tires-leaning-top-75455/
Old Mar 3, 2009 | 05:02 PM
Stuka's Avatar
As far as gusseting the axle and C's, a rubicon front axle has the same strength issues as the D30. The front D44 in a rubicon is only half a D44. The 3rd member has D44 gears and carrier. But past that its a D30.
So if you go with a Rubicon, I would still plan on upgrading the front axle with all least C gussets.
Old Mar 3, 2009 | 05:07 PM
Robar's Avatar
I have been running 35s on my D30 for about a year. So far so good. I have Evo C2 gussets, but they are still sitting in a box and I can't afford cromo shafts yet, so I hope things keep going like they are.
Old Mar 3, 2009 | 05:25 PM
livin's Avatar
thanks everyone....
Old Mar 3, 2009 | 05:32 PM
good point...
I think lots of people have managed to get away with tossing bigger tires on, but without taking care of the axels by beefing them up I believe it's only a matter of time before the leverage takes over especially on the passengers side with the extra length on that tube
