Driveshaft Install
Old Mar 11, 2009 | 11:29 AM
JoKer885's Avatar
Default Driveshaft Install
Does anyone have any write-ups and/or pics of doing a rear install of the rear driveshaft. From talking to the J.E. Reel shop I will be chaning the flanges on the diff and transfercase. I'm just trying to figure out what I'm getting myself into. Anyhelp or input is much appreciated.
Thanks
Ben
Old Mar 11, 2009 | 08:57 PM
Eugene's Avatar
I put in front and rear JE Reel 1350's on my JK with no problem. It's an easy install. I replaced the flanges on the transfer case but did not need to change the flanges on the diff's, but you may have a different application.
The most trouble you will have is with the nuts that hold the flanges on the x-fer case. If you have an impact wrench then you'll make quick work of them. If not a long breaker bar on a ratchet helps. If you have trouble getting them off I have heard some will actually roll the Jeep back while bracing the wrench on something.
The rest of t he install is just removing and tightening bolts. If you have the double cardon u-joint, that goes on the x-fer case side.
Old Mar 11, 2009 | 10:49 PM
aldaman's Avatar
Thanks
Ben
Here's a link w/pictures of an old thread...Hope this helps...Good luck on the install...
https://www.jk-forum.com/forums/jk-write-ups-39/installing-je-reel-1350-rear-driveshaft-28160/
