Take muffler off??
Has anybody just taken the muffler off? I think it might be a tad illegal, but im thinking about doing it....Is their any problems this could cause? Has anybody done it?
i ran it muffler less for .. 10 minutes. i then put a streight true magnaflow. i think the sound is not that much different. just try it. the hardest thing is to remove it from the rubber... thingies.
Not back pressure, but an appropriate pipe diameter to assure velocity without restriction. A large can creates a larger heat sync, and loss of heat contracts exhaust gas, slowing it down.
Back pressure isn't an issue nor solution. You put a fat pipe on your JK you'll lose exhaust velocity, just like the tuner crowd. Then someone from that crowd decides that it's "back pressure" that needed, it's not.
So as long as you run the stock size 2.5" pipe you'll be cool.
I actually lost about 1-2 mpg with the Gibson, Small price to pay -- lol.
