Wierd electrical issue
Originally Posted by ZombJep
Terminals are tight but could use a little polishing. Going to check out my ground wires like suggested.
Just my 2cts.
Respectfully,
BoneShkr
I have a similar issue if not the same. Next time it happens put it in neutral and then try to start it. If it fires right up then it's the exact same problem I have. After three trips to the dealership I finally was able to bypass the customer rep and talk directly to a mechanic. He suggested I try that since I couldn't duplicate the problem in front of him. Next time it wouldn't start, I put it in neutral and it fired up right away. He said it was a sensor in the automatic transmission that was not recognizing that the transmission was in the right position in order to start. Putting it in neutral will bypass it allowing me to start it until I got it fixed. That was over a year ago and I never have replaced that sensor. I just put it in neutral any time it won't start and it fires right up. I look at it now as another type of security system.... ( Although a very intermittent one )
It also gives my jeep some character... That, and I'm just too lazy to fix it.
Also, when mine first started doing it I would be able to start it on the second try as well. Then it got worse and wouldn't start at all until sometimes the 5th or 6th attempt. A few times it wouldn't start at all and I would come back a few hours later or the next morning and it would start up without any issues. Hope this and my previous post will help. Good luck.
It may be that my Jeep just doesn't want to leave the brewery. She's a bit of a lush.
