Huntsville Alabama / Tennessee Valley Chat
Old Feb 28, 2010 | 04:11 PM
  #3811
BullDawg's Avatar
Originally Posted by randy payne
Is this a recall or what? Does this apply to my 09
It is for 07-09 built before march 09. It is just a TSB only though not recall. Do a search for TSB 23-010-09 Rev A. If you have wind noise, see if your top sits more like my picture before the kit replacement above. It's significant change in seating position of the header plate.
Old Feb 28, 2010 | 04:14 PM
  #3812
BullDawg's Avatar
Originally Posted by JK-Rubi
Haven't noticed any clock issues with Wilbur. I do think I have the long crank time problem. Dennis noticed it first - asked me why I have to hold the ignition key on so long when starting. According to the TSB, my cam sensor probably needs replacing.
What is the TSB for cam sensor. I have noticed long crank times but it's not always there. Some dats it starts right up, while others are significant delayed starting (5 sec or more)
Old Feb 28, 2010 | 06:41 PM
  #3813
JK-Rubi's Avatar
Default Long Crank Times
Sounds exactly like mine Steve. See this TSB ---> http://project-jk.com/jeep-jk-tsb-re...-camshaft-gear
Thought it was just a "Jeep thing" until Dennis brought the aberrant behavior to my attention one day when he was riding with me. Sure enough, I've watched Dennis start his engine, and he barely turns the ignition switch and then immediately releases it - his JK starts right up every time.
Old Mar 1, 2010 | 06:39 AM
  #3814
BullDawg's Avatar
Originally Posted by Denny2565
Gary and I were discussing engine rpm at highway speed so I checked mine on the interstate today. Going 70 mph, my rpm's were 1950. At 80 mph, my rpm's were 2200.
I also pick up some new spark plugs today. I was going to try some Bosch plugs, but after looking through a few non-jeep forums, Bosch had mixed reviews. There were almost as many bad reviews and there were good reviews so I decided to go with a basic NGK platinum.
Hey Denny.. I assume you have had the speedo adjusted for tires/gears/mods right? What gears are you running? Mine are the stock 3.23's or whatever. With the manual I can't hardly run in 6th gear because there's just not enough torque below about 65 to pull it and I think I'm running about the same RPM's as you but smaller tires most likely... Still stock Rubicon tires. Want to go to 4.10's but not until I upgrade to 33's or 35's. Bumpers/winch/more lift probably first. Ha.
Old Mar 1, 2010 | 07:10 AM
  #3815
08RedRecon's Avatar
Originally Posted by USAF_GroundRat
Thanks!!!
My wife bought me new BFG KM2 35's with 17" KMC XD Hoss 795 wheels and the Rugged Ridge XHD Bumper like Jason has... I can't fricken wait!!!
WOW, thats an incredible bday list. Happy bday old man.
Old Mar 1, 2010 | 09:30 AM
  #3816
racinfast002's Avatar
I run NGK's in the go fast stuff...they seem to make a good plug
Old Mar 1, 2010 | 11:06 AM
  #3817
Wilky's Avatar
Shout out to Wilky.. Finally got around to putting the Rubicon springs and shocks on this weekend that you donated to my cause. Gained 1" in lift but the ride is totally different. The squishy feeling stock ride is gone. Tight ride now. The shocks made a huge difference alone. Wished I had got a little more lift but for the ride alone, it was worth it.
No worries....they were just taking up space in my garage.
Hope you enjoy.
Old Mar 1, 2010 | 11:49 AM
  #3818
USAF_GroundRat's Avatar
Thanks brotha! How are things in the sand box?
Old Mar 1, 2010 | 11:52 AM
  #3819
Originally Posted by Bama JKX
I've noticed that my clock is losing time also. It actual made me late for a meeting two weeks ago.
Hey... I have the same problem. I actually thought someone got under my hood to try and break into the Jeep. I pulled over and checked everything out and it was all good. I have noticed it 2 times since then. This is something that has not happened until a few months ago. WTF is going on?
Old Mar 1, 2010 | 12:35 PM
  #3820
uofagrad05's Avatar
Just to let you know, I had went to the Dealership with this problem earlier in the Jeep's life. The service man asked me how much time it was losing in a given period of time. At the time, it was not enough for a warranty claim. The man said to wait a few mths and it should get worse and then I can claim it. I plan to take it in next week, so I will let you know then. If someone takes theirs in before then, post what they said.
