Alpha Expedition: Gobi Roof Rack.
Old May 2, 2010 | 07:32 PM
  #421
Northern Wrangler's Avatar
Email sent! Thanks!
Old May 4, 2010 | 03:04 PM
  #422
b5rider's Avatar
The rack is being "packed up and shipped today" and I should get it Wednesday!
Old May 4, 2010 | 07:33 PM
  #423
Samboko's Avatar
Default Design Change?
David,
I just saw this the other day on a different forum, and noticed it was different than my rack which I bought in February. I think this could be the solution my problem. My rack has the anti-sway tensioner mounted on the rear of the bar, and this one is moved to the front. I find that mine is sort of hanging off the rear of the body work, only pressing about 50% on the frame. I think I'll make up a tab and weld it on. Were you aware of this change?
Compared to mine (you can just see it):
I know some other people have had this issue, looks like an easy fix. Glad to see they addressed it!
Old May 4, 2010 | 11:21 PM
  #424
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
Actually I have also just recently found out about the minor update on triangular metal plate. and the tab to the front. Currently I have the same version as yours as well.
Originally Posted by Samboko
David,
Old May 5, 2010 | 04:40 AM
  #425
banessi's Avatar
David,
I was just thinking about these too. Mine (on a 4 door) also press on the very rear corner of the pad on the body. That has, over time, pushed the pads off the front and they are slowly starting to peel off the body at the front (I'm assuming from wind, weather, and pressure to the rear). I was debating just removing the pads and tensioners all together since the rack seems so solid anyway. Not to mention, I forgot to loosen these in the past and almost ripped my rear light off one side. Has anybody else just removed the tensioners all together?
Old May 5, 2010 | 11:14 AM
  #426
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
You do NOT want to remove the tensioner. It help control the side to side sway of the load. And as for the location of the tensioners go... as long as it is on the side of the body it will assist the side to side sway doesn't matter if in the front or the back.
Old May 5, 2010 | 03:24 PM
  #427
grant6923's Avatar
David,
Is there away to order this new bar with the new tensioner?
Old May 6, 2010 | 05:15 AM
  #428
GON WHLN's Avatar
I couldn't tell from the pics.....
Does the rack for the soft top 2 dr have any ability to remove part of the rack for a sunroof? Or are you looking at the rack always above your head?
Old May 6, 2010 | 01:20 PM
  #429
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
The front driver/passenger side is wide open. There is an optional Sun roof insert for the rack for additional storage area.
Old May 6, 2010 | 01:21 PM
  #430
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
Originally Posted by grant6923
David,
I will check on that with pricing. But the new location isn't better or worst since its main job is to stabilizing the side to side sway.
