Kicker Factory Replacement Overhead Sound Bar Speaker Kit
Old Nov 27, 2007 | 02:50 PM
  #41
fishit's Avatar
So do these same speakers plug into the front two speakers as well. If they are the same size, why are they only being pushed for the sound bar?
I may be stupid.
Old Nov 28, 2007 | 07:39 AM
  #42
quadratec's Avatar
Sponsoring Vendor
I was told that the front speakers are mid range speakers and really do not benefit from any type of upgrade - so no money was spent in development of adapter rings/harness to swap them out. If there is enough demand I'm sure it will be done.
-jim-
Old Nov 30, 2007 | 10:56 AM
  #43
gr82bagn's Avatar
I just finally got around to putting the new speakers in,, big improvement over the standard system. I'm a very happy camper.
Old Nov 30, 2007 | 01:55 PM
  #44
fishit's Avatar
allow me to reveal just how clueless i am bout audio installation. do i need to disconnect battery or anything when installing these speakers?
Old Nov 30, 2007 | 02:19 PM
  #45
Robar's Avatar
No, you shouldn't need to disconnect the battery. Just turn off the vehicle's stereo system.
Old Nov 30, 2007 | 02:59 PM
  #46
fishit's Avatar
gracias!!!!
Old Dec 7, 2007 | 04:27 AM
  #47
souvlaki99's Avatar
Originally Posted by souvlaki99
What makes these $130 speakers better than the same ones I can get on another website for $40 a pair like on Cartronix?
Anyone know the difference (if any)?
Old Dec 8, 2007 | 06:23 AM
  #48
08JK's Avatar
The one from Quadratec comes pre-wired with 2 metal adapter plates so the speakers can fit into the soundbar. Without these plates, I'm not sure how we can install them because the speaker sizes are little different than the original ones. The installation was easy, there are 2 options that you can choose; one without the factory grills and one with them (although it did not say in the instruction, but I chose to do it with the factory grills on). Just simply unscrew the factory grills, install the new speakers into the adapter plates, plug in the plastic thingy, and screw them back in along with the grills into the soundbar. Hope that helps.
Old Dec 8, 2007 | 09:10 AM
  #49
BLKRUBI's Avatar
Originally Posted by armycop
I am one of the oddballs that actually thinks the Infinity 7-speakers and factory sub are pretty decent. I have a 2-dr which may be a reason, maybe the 4-door needs more oomph?
I must be one also. I have a 4 door and it sounds fine to me, minus the sounds bar speakers so I'm interested in these.
Old Jan 19, 2008 | 07:13 AM
  #50
ROKLIMO's Avatar
I just installed these in my Rubi. They are a huge improvement over the so called "premium Infinity" sound bar speakers. Even with the limited power provided by the factory amp, they sound much better.
I'm guessing that when they made the decision to limit power to the sound bar, they also decided to use junk speakers since no one could hear them anyways...
