May Special: VIAIR JK Specific Onboard Air Systems
Old May 3, 2012 | 03:50 PM
Air Werkz's Avatar
Former Vendor
Default May Special: VIAIR JK Specific Onboard Air Systems
We are new here to the forum, as you can tell from our post count. Some of you may have heard of us, and maybe even been customers. We specialize in air compressors, onboard air systems & air accessories. We have even developed our own bolt-on air system for UTV's. We are excited to be on this forum and look forward to working with the members here. All we do is air.
We are starting out by offering a month of May special for 2 new kits by VIAIR. They are bolt-on onboard air systems for the JK. Let us know if we can help you out or if you have any questions. We will be having 2 specials this month to kick things off, so be sure to check out our other special.
Introducing VIAIR's just released JK specific kits, that are a direct bolt-on!
You can now see both these systems on our site!
Kit 1:
400C & 450C ADA System
These system mount directly to your brake booster, using the supplied bracket, and have a small built-in air reservoir. Because of this reservoir, you can operate air locker. It already has a built-in 105 PSI pressure switch, which is great for most aftermarket lockers. A wiring harness, mounting bracket, lighted switch, delphi connector, fill hose with tire inflation gun are all included. Again, this is a direct bolt-on system for the 2011 & 2012 JK.
Bonus: Onboard-air.com is including a free air relocation kit with the purchase of a VIAIR ADA system. Use this to relocate another air chuck at the back of the vehicle. ($19.95 Value)
400C ADA (07-11 & 2012 JK): $399 + FREE Shipping
450C ADA (07-11 & 2012 JK): $429 + FREE Shipping
Kit 2:
High-Speed & High-Pressure 2on2 System
Using 2 compressors (High speed using 400C's, and high-pressure using 380C's) on top of a 2 gallon tank, these are the ultimate OBA system for your Jeep. These kits, using a supplied bracket, bolt directly onto the front crossmember of your vehicle. These will fit in between your radiator and engine, and is a direct bolt-on system for the 07-11 Jk's, ONLY. Harness, air manifold, dash panel gauge and regulator are all included. The regulator allows you to run your air lockers. This system will do it all!
Bonus: Onboard-air.com is including a tire inflation gun with the purchase of a 2on2 system. ($27.95 Value)
Dual 450C CFM: 4.55
Dual 380C CFM: 2.54
150 PSI 2on2 (07-11 JK): $599 + FREE Shipping
200 PSI 2on2 (07-11 JK): $629 + FREE Shipping
Old May 3, 2012 | 04:20 PM
Air Werkz's Avatar
Former Vendor
Originally Posted by Bimmer335
I always did like 2 on 2 weather it be girls or drinks lol so I will be ordering the 2 on 2 kit ...will I be able to run air tools with this?
Yes, you can run air tools with this kit, because it does come with a regulator. You would be able to pull all lugs off a wheel without needing to stop and let the tank pressure build up. By the time you grab your other wheel, it would be pressured up and ready to go. The Hi-Speed 2on2 kit has a very fast recovery time.
You can run other air tools in spurts, and definitely is great when you are on the trail and no other air source is around.
Old May 3, 2012 | 04:42 PM
jkfisher84's Avatar
Silly noob question but where can u mount something like this?
Old May 3, 2012 | 04:49 PM
steed77's Avatar
Mine sowed up this week. I hope to install it this weekend.
Looks nice.
Old May 3, 2012 | 04:55 PM
Air Werkz's Avatar
Former Vendor
The ADA system (compressor with small reservoir) mounts off the brake booster, available for 07-2012 JK. The 2on2 (2 compressors on a tank) mounts to the front lower crossmember. It will sit in between the engine and radiator. Only available on the 07-11 Jk's.
well some females prefer to be mounted from behind....oooh the on board air system lol my bad
a comical bump for a great company !!
Thanks!
Looks nice.
Sweet! Keep us posted on the install.
Old May 3, 2012 | 05:43 PM
Air Werkz's Avatar
Former Vendor
Looking good!
I will throw in a small gauge, along with the already tire inflation gun, for you if you buy the 2on2 kit. Deal?
Old May 3, 2012 | 06:02 PM
Air Werkz's Avatar
Former Vendor
Give me a call tomorrow @ 480-442-8136 and we will get everything going for you!
Thanks.
Old May 3, 2012 | 06:15 PM
Atch's Avatar
The crossmember that the 2on2 bolts to, is that the same crossmember that gets cut off when installing the Evo 1/4 bumper?
Old May 3, 2012 | 06:16 PM
PGT's Avatar
PGT
any installed pics of kit 1? I'm looking for something for my '12 modl
Old May 3, 2012 | 06:21 PM
Redman333's Avatar
I'm so excited you guys are looking at the 2012s but is there plans to make a 2on2 kit for the 2012s. I definitely want a tank setup but not sure where to put it. I have a jku also so it may be easier to do but I haven't seen anything yet.
