What would you like in a snorkel design?
Old Jan 27, 2011 | 09:18 AM
  #451
MagnumD69's Avatar
Default Will this snorkel work with windshield-mounted lights?
KC lights & brackets?
Or, is this a Rugged Ridge-compatible design only?
Old Jan 27, 2011 | 01:26 PM
  #452
Rugged_Ridge's Avatar
Former Vendor
Well... Hard to say... We have it working with our W/S frame light mounting brackets. Everyone looks to have it mounting in the same spot but I have not ordered everyones brackets to test. Good news is that they are not that expensive . With that said I would think it would fit with minor trimming.
Old Jan 28, 2011 | 06:26 AM
  #453
MagnumD69's Avatar
OK, thanks for the info. I'm very curious to see how this turns out. I'd rather not trim brackets, nor buy new ones if it can be prevented by tweaking the snorkel tube a few hundreths of an inch or so to accomodate. It may not be a big deal either way.
Old Jan 28, 2011 | 09:49 AM
  #454
mirewolf's Avatar
One inlet at the top will be used for all designs.
(1) Raised "Ram" intake
(2) Low mount intake
(3) Pre-filter intake
Caps head bolts will secure with two stage sealing steps on main intake housing...
Have you fabbed some examples, or are you still working on the base?
Old Jan 28, 2011 | 11:28 AM
  #455
Former Vendor
We should have a rapid prototyped version installed by the end of next week. I will see if I can post pictures then.
Old Jan 29, 2011 | 04:31 PM
  #456
Ario56's Avatar
As soon as we are finalized and into production I'll let you know... If you guys are still your heads than maybe, just maybe our fellow manufactures are as well.
They are smart guys so anything we can do to keep it under cover the better.
Sorry.
Discussing this with a few gear head buddies today... We figured the firewall would have to be cut in some way to allow the intake tube to pass through. (kind of a given) Hoping that's all that would really need to be cut.
Old Jan 30, 2011 | 02:23 PM
  #457
mataylor1's Avatar
Default what i would like to see
Is a snorkel application that can be used with your mirror relocation brackets, i drive doors off all the time, so a mirror relocate kit was essential, i believe no snorkel lets u have that kit cause they run down side of windshield, maybe something that runs up front of windshield frame so miiror relocate kit can be functional.
Old Jan 31, 2011 | 04:06 AM
  #458
Former Vendor
... Got to make it work with our other products. It would be sad if we could not make that happen .
Old Jan 31, 2011 | 04:07 AM
  #459
Former Vendor
You got me..... So where did you guys figure the cut would be made seeing how it has to work with our dual battery tray?
Old Jan 31, 2011 | 05:45 PM
  #460
Ario56's Avatar
You got me..... So where did you guys fingure the cut would be made seeing how it has to work with our dual battery tray?
Wait... What?
Are you saying it doesn't get cut? How would the inlet make it's way from the snorkel to the air box? Are you trying to make me crazy? (crazier)
