Sponsored by:
Sponsored by: DashLynx
2007 leaking water onto inside door handles!
Old 05-02-2011, 09:54 AM
Meredith124's Avatar
Default 2007 leaking water onto inside door handles!
First off, I know this topic might be like beating a dead horse, but, I still haven't found an ultimate solution for my leaky soft top!! Any help/ tips would be very much appreciated!!!
Old 05-02-2011, 09:56 AM
Unclebuck12's Avatar
X2 on the problem!!
Old 05-02-2011, 10:00 AM
Lol somebody please help us!
Old 05-02-2011, 10:03 AM
RubiDude's Avatar
I have had the same problem...finally found a fix! You need to put some type of weatherstripping/foam on top of your door surrounds. I went to NAPA and bought the foam that people line the top of their truck beds with prior to putting a cap on...cushions the top and protects the metal from getting scratched. It was $8.99
The bad news is the sticky backing is not that sticky and I am sure will come off! I plan to just run a bead of crazy glue gel under it...you can always get it off if need be later with a blade and goo gone. I did this last week prior to the big rain/storm that was blowing across the country and stayed bone dry! There may be more detailed instructions on here somewhere, as that is where I got the idea...but hey it works!
Old 05-02-2011, 10:08 AM
So just on the top of the door surrounds? Did you remove the existing whether strip?
Old 05-02-2011, 10:10 AM
RubiDude's Avatar
On top of the plastic door surrounds exactly! Mine did not have any weatherstrip there at all. I ran it the full length of the front door surround...no issues since.
Old 05-02-2011, 10:14 AM
Oh ok, gotcha! I have tried putting foam/whether stripping here and there but it always seems to still leak! It's like a never ending battle lol!
Old 05-02-2011, 10:25 AM
Elegabalus's Avatar
The best fix for mine was when I took it to a shop and they stuck a piece of 2x4 in the door and reamed on the top corner.
He rolled down the windows, placed a piece of board in the door and pushed in the top right corner... little to no leaking since (they did this around last November).
Old 05-02-2011, 10:29 AM
I don't understand? They reamed the top corner of the soft top with a 2x4?
Old 05-02-2011, 10:58 AM
Elegabalus's Avatar
nope, the door itself.
2x4 in the door jam, then push on the top of the door.
Someone on this forum said it was an old fix.
Quick Reply: 2007 leaking water onto inside door handles!
