2010- Knock Sensor Circuit 1 P0325
Old 05-31-2012, 05:22 PM
Blakspire's Avatar
Default 2010- Knock Sensor Circuit 1 P0325
So I recently had my Jeep in a shop to replace the throwout bearing. Upon recieving the Jeep it had the stored code P0325(Along with others, but I got those figured out). Keep in mind, that this is a stored code, not an active one. If I clear the code, I can run through the entire RPM band and not set the CEL. It is only after a random amount of time, at a random RPM that it will trip.
Any ideas? Its hard to pin this on the shop in good faith, seeing as it submarined not too long ago.
Old 03-25-2013, 06:54 PM
wranglerbrotherhood's Avatar
I got the same code after I replaced my clutch/TOB. Haven't done anything about it yet. I have a feeling it's just a faulty connection, I've been looking for answers on here.
Old 09-05-2014, 04:13 PM
Rtwill78's Avatar
My throwout bearing is squealing and I just threw the P0325 code also. Did you ever find a cause/solution to this? I'd hate to have this keep popping up after getting all the work done next week.
Thanks in advance!
RT
Quick Reply: 2010- Knock Sensor Circuit 1 P0325
