2013 high RPM's???
Old Dec 6, 2012 | 08:47 PM
Sharkbait98's Avatar
Originally Posted by TheTerminator
You said you have 255 tires with 16" steel wheels. As far as I know they don't have stock tires in this size. You probably meant to say 225 tire? If so, then you need to take that into account, as it's more of a 28" tire, not 31". With a 28" tire your RPMs at your speeds according to rpm calculations should be:
@65mph: 2415 rpm
@70mph: 2601 rpm
With a 31" tire it should be:
@65mph: 2181 rpm
@70mph: 2349 rpm
Thanks really helped, makes sense now. By chance do you know what the same speeds would be riding on 33's? Sorry about the numbers dyslexic kicked in lol
Old Dec 6, 2012 | 08:50 PM
Skid_kid thanks on the info did not know that always thought 410's was the only option.
Old Dec 6, 2012 | 08:53 PM
Skid_Kid's Avatar
No problem, anytime!
Old Dec 6, 2012 | 10:26 PM
TheTerminator's Avatar
No problem. If you get 33's, they will be more like 32's when mounted. This calculation is based on 32" actual tire diameter:
@65mph: 2113 rpm
@70mph: 2275 rpm
If you do happen to get a tire that is 33" mounted (this tire is likely going to be advertised as a 34"), it will be:
@65mph: 2049 rpm
@70mph: 2207 rpm
Old Dec 7, 2012 | 03:51 AM
Rule18's Avatar
Default Jpop's chart - good info
Check this out, it has all the answers and it's accurate...
http://farm8.staticflickr.com/7159/6...9b861446_b.jpg
Old Dec 7, 2012 | 04:23 AM
fitzz47's Avatar
I have a 2013 JKU Sport with 3:73 gears,auto and 255/75/17 tire package I recently went on a 500 trip and averaged 21.2 mpg @70mph at around 23-2400 rpm.If I went up to 75mph
it went down to 17 mpg.I ran 36 psi. in the tires which increased to 38 as the tire heated up.
