2014 oil leak
2014 oil leak
It's noticed some oil running down both sides of transmission. Engine oil. Can't find any from the top of the block, but can't get behind far enough to see or feel. Levels are still good, hasn't dropped on my oil pad yet, but there is a little on the transmission cross member. Still under warranty, 2 week wait to get it in to the dealership. Anyone have a similar leak story and maybe a guess as to what I'm looking at here?
For your reading enjoyment! https://www.jk-forum.com/forums/stoc...oblems-303650/
Have you had the oil changed recently? My last oil change the grease monkey hosed up the rubber o-ring on the oil filter housing. Oil went everywhere.
While it's a shot in the dark, it's easy to check the housing while you're waiting to get into the dealer.
it's noticed some oil running down both sides of transmission. Engine oil. Can't find any from the top of the block, but can't get behind far enough to see or feel. Levels are still good, hasn't dropped on my oil pad yet, but there is a little on the transmission cross member. Still under warranty, 2 week wait to get it in to the dealership. Anyone have a similar leak story and maybe a guess as to what i'm looking at here?
Changing the cooler isn't that bad. 4-5 hours max. Cleanup takes awhile but once your in there it not that hard there are just a fair amount of steps to follow. motor city mechanic on YouTube has a good step by step with torque values. Make sure you get the intake gaskets also
