6 speed gear whine?
Old Oct 25, 2010 | 06:38 PM
ytee's Avatar
Default 6 speed gear whine?
My 6 speed seems to have a little gear whine starting. The whine is only noticeable in 2,4, and 6. Has anybody else noticed this? I am going to change the fluid in the tranny and transfer case but I really dont expect this to help.
Chris
Old Oct 25, 2010 | 07:56 PM
D0ppleganger's Avatar
Can you describe it a little better?
If you have a body lift it could be due to that. I've heard of guys not being able to shift into the even gears or popping out of gear after a body lift.
It also could be when you shift into those gears. I've experienced that when I start in second (which I don't do often) that it whines but that is because of the strain.
Old Oct 25, 2010 | 08:04 PM
2climbbig's Avatar
usually a whining sound is indicative of bearings going out. My guess is its in your tranny... but its just a guess. Should take it to a mechanic to figure it out
Old Oct 26, 2010 | 09:50 AM
it could be the tranny dying but if you have low miles like me (< 3k) then i doubt it.
Old Oct 26, 2010 | 03:46 PM
ytee's Avatar
I don't have a body lift. I agree that the whining is probably the bearings starting to go out.
Chris
Old Oct 27, 2010 | 02:37 AM
JeepaRoo's Avatar
the 3 6 speed wranglers ive had whined ever so slightly.. esp when cold and esp in 2nd gear..
its a truck transmission and a little of that is normal...
-Christopher
Old Oct 27, 2010 | 06:19 AM
ytee's Avatar
Thanks I am not too worried about it, i am going to change fluid and run it till it quits.
Chris
Old Oct 27, 2010 | 07:22 PM
ytee's Avatar
Update: Replaced the tranny fluid with Royal Purple Synchromax and it seems to have quieted the whine down quite a bit. There was a bunch of metal on the magnetic drain plug though.
Chris
Old Oct 27, 2010 | 07:24 PM
opdsgt's Avatar
It's commonplace for the drain plug to be fuzzy.
Old Oct 27, 2010 | 07:27 PM
MoabBrink801's Avatar
I have 3100 miles with the same noise it has me a little worried but I've got 32000 more miles of warranty so if it gets worse I'll take it in
