adding power door locks (oem latches, oem wiring, viper 5701 alarm with remote start)
I just bought a 2012 Black Jeep Wrangler Unlimited Sport without power windows and door locks. I could not understand why power windows and door locks were over $2,000. For anyone in my situation that did not purchase power windows and door locks, I am about to start an install of power door locks with oem latches ($155), oem wiring ($185) and an aftermarket viper 5701 alarm system with remote start.
PART NUMBERS:
LATCHES:
4589505AG DRIVER FRONT
4589276AI PASSENGER FRONT
4589023AI DRIVER REAR
4589048AI PASSENGER REAR
4589048AI TAIL GATE
WIRING:
68066013AD DRIVER FRONT
68066012AD PASSENGER FRONT
68066033AB DRIVER REAR
68066032AB PASSENGER REAR
TAIL GATE IS A BODY WIRING HARNESS
PART NUMBERS:
LATCHES:
4589048AI TAIL GATE
WIRING:
If I understand what brad2012 is doing correctly, he's using the stock motors in the doors, then using the stock wiring harness to get the signal inside the Jeep so that he'll retain the factory quick-disconnects. From there though, he'll bypass the Jeeps wiring system and connect the locks to the Viper instead. It's a pretty slick idea, and if it works out well, I might have to start saving my pennies!
Remote start on a manual is possible... but none of the OEMs do it (that I know of) and none of the aftermarket kits recommend it. To be safe, the remote start systems verify that the vehicle is not in gear. The problem is that the manual transmission on our Jeep doesn't have a way to report which gear it's in, or if it's in neutral. You'd have to bypass the clutch start switch, and then be sure that you _never_ left your transmission in gear when you parked your Jeep. So to avoid lawsuits, the aftermarket manufacturers are pretty strenuous about this being a bad idea for a manual transmission.
