Alignment shop san diego
Old Jul 27, 2013 | 03:14 PM
wewpzee594's Avatar
Default Alignment shop san diego
Any good alignment shops that know how to adjust everything back within specs after adj track bar and LCAs open on a Sunday? I'm pretty sure I set everything up wrong and have a weird vibration at 20mph then goes away. I know a ds is in the near future, but I didn't have any issues till putting LCAs in at the tf specs on the instructions
Old Jul 27, 2013 | 03:56 PM
pismo61's Avatar
East County Alighnment shop in Santee.Been around forever.Not sure about Sundays
Old Jul 27, 2013 | 06:50 PM
Woody's Avatar
Vet Army
ROGER DANIELS alignment in El Cajon is the place to go, they're right by the airport.They know jeeps inside and out. Mike Fortner there is a jeep owner and will treat you right.
Old Jul 27, 2013 | 07:36 PM
wewpzee594's Avatar
That name sounds familiar. I'm going to give it one more try tomorow and if not ill take it in. Thanks guys
Old Jul 28, 2013 | 08:39 AM
kjeeper10's Avatar
Vet Army
Why don't you do it yourself ? Do you have a flat driveway and tools?
Very easy way to check caster is off pinion. Knowing pinion will give a close estimate of caster.
Toe is is very easy to check yourself. I have mud tires and screwed a small screw into a lug each tire. Ran a tape measure across front and back. Adjusted for 1/8 in.
Centering the axles/assuming the front) is not that hard either.
Old Jul 28, 2013 | 08:53 AM
sm_rubi's Avatar
x2
Haven't used them because I'm in the North County but lots of people out east have and have nothing but good things to say about them!
Old Jul 29, 2013 | 07:42 PM
CharlesS's Avatar
X3 On Roger Daniels
When your vehicle is lifted and need the alignment done right; Roger Daniels is the place to go. He not only does alignments, but suspension work and fabrication of some parts to ensure the job is done properly.
Roger has been aligning my Jeeps for more than 10 years.....
8517 Ablette Rd
(between Kenney St & Prospect Ave)
Santee, CA 92071
619 562-7969
Roger Daniel Alignment & Brakes
Old Jul 29, 2013 | 08:00 PM
wewpzee594's Avatar
Thanks guys ill keep those saved. Ended up getting some sleep finally and took another try at doing it myself, solves my problems. Still have to adjust toe in but that seemed pretty simple
