Alignment shop san diego
Any good alignment shops that know how to adjust everything back within specs after adj track bar and LCAs open on a Sunday? I'm pretty sure I set everything up wrong and have a weird vibration at 20mph then goes away. I know a ds is in the near future, but I didn't have any issues till putting LCAs in at the tf specs on the instructions
Why don't you do it yourself ? Do you have a flat driveway and tools?
Very easy way to check caster is off pinion. Knowing pinion will give a close estimate of caster.
Toe is is very easy to check yourself. I have mud tires and screwed a small screw into a lug each tire. Ran a tape measure across front and back. Adjusted for 1/8 in.
Centering the axles/assuming the front) is not that hard either.
Haven't used them because I'm in the North County but lots of people out east have and have nothing but good things to say about them!
X3 On Roger Daniels
When your vehicle is lifted and need the alignment done right; Roger Daniels is the place to go. He not only does alignments, but suspension work and fabrication of some parts to ensure the job is done properly.
Roger has been aligning my Jeeps for more than 10 years.....
8517 Ablette Rd
(between Kenney St & Prospect Ave)
Santee, CA 92071
619 562-7969
Roger Daniel Alignment & Brakes
8517 Ablette Rd
Santee, CA 92071
619 562-7969
Thanks guys ill keep those saved. Ended up getting some sleep finally and took another try at doing it myself, solves my problems. Still have to adjust toe in but that seemed pretty simple
