Alright i cant find this oil change
Bought oil changes from the dealership, my owners manual said my jeep would tell me when an oil change is needed, but I'm over 6000 miles right now. When will (if it will) my oil change light come on?
Don't listen to the computer that's asking for trouble especially if your not checking your oil level. I know your is new but you still should check your fluids on a regular basis that is simple preventative maintenance. If it was never change from when you bought it how do you know they even put enough oil in it to begin with just saying
It's not a mileage or time (date) counter. Nor, as mentioned, does it measure volume, so check your level frequently. Don't go over your warranty requirements for max mileage and time. What's the max interval now? 10k/1 yr, I think.
If you change your oil with or without the OCI warning, be sure to reset the OCI.
The way some folks use their jeeps a 2-3,000 mile change interval really is necessary but others can easily go 10k or more.
What happens if the oil light does'nt come on( burnt out bulb) then what
Same here man I got it from the dealer the next day I did an oil change since it was used! And now I don't really use my jeep as much so I still do it at every 3k maybe let it go couple hundred over 3k but no more than 4k, my jeep burns oil so I have add a quart about every 800 miles depending on the oil I used
I change oil and filter every 5,000/miles (as well as rotate my tiires) and have done so my whole life.
I purchased my first Jeep (CJ-7) new in 1982 and put almost 250,000/miles on it with zero engine trouble. Have driven other cars well over 100,000/miles using this same interval and have yet to have an issue related to oil changes.
For me it is easy .....every 5000 miles is easy to track and remember.
KG6SLC aka Eugene
KG6SLC aka Eugene
