Annoying Noise Problem!!!!!
Old Feb 20, 2008 | 05:16 PM
  #121
This is gonna sounds crazy but....I actually think i hear the radio even when its turned off. Sounds like the radio is still on but very very suddle. My brain is either catagorizing wind noise as faint radio sounds or the damn radio is always on....cant put my finger on it.
Yeah yeah, it sounds like I've gone nuts, but someone on here has to have heard it too.
Old Feb 20, 2008 | 05:53 PM
  #122
imacb278's Avatar
Veteran: Navy
I have the Mygig setup in my JK too. I've heard the sound but it goes off after a minute or so, or when you open the door. I think it is because the radio still has power even when you turn the ignition off. Just my 2 cents anyway.
Old Feb 20, 2008 | 05:59 PM
  #123
TracSean's Avatar
I have the same door noise. October 1 I took it in to the dealership and they tried many things to fix the sound. Finally they adjusted the striker inward appx 1/16" and the noise was corrected...
... The noise came back this week.
Old Feb 20, 2008 | 07:53 PM
  #124
Maybe we both lost our marbles?!
Thanks for the post.
Old Feb 23, 2008 | 03:15 PM
  #125
HULKGREEN's Avatar
I finally tried after more than 6 months of " adjusting the striker " to go to the dealer and insist they install the revised latch................. driver and passenger!!
My JK has never been so quiet !!!!!
It worked !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I love my JK again !!!!!!!!!!
Old Feb 23, 2008 | 03:21 PM
  #126
capt scotty's Avatar
MAYBE YOU SHOULD PLUG ONE EAR... TO KEEP THE WIND FROM BLOWING CLEAR THROUGH.........
I had an annoying noise coming from my passenger side.. Then I made my sister in law get out... problem solved!!!
Old Feb 24, 2008 | 10:31 AM
  #127
HULKGREEN's Avatar
Originally Posted by neoxxis
So you mean they installed the 4589277AF Latch Assembly and it cleared the noise?
I went to the dealer and all they said is this piece is the original one I already have.
So they wouldn't order and install it "just for fun". They moved the latch inward a bit but this did not work at all.
The only way I found to get rid of the noise was to move the latch inward a "lot" but then the door is not inline with the body anymore...
Not cool.
I want the new latch!
YES !! and the 4589277AG !!!!!
I had to do some " convincing " but told him I would not be back for the noise EVER again IF he would " try " the revised latch ....
He went for it and it WORKED !!!!
Old Feb 24, 2008 | 03:23 PM
  #128
TracSean's Avatar
I sprayed silicon spray in the latch area and the sound is gone.
Old Feb 24, 2008 | 04:48 PM
  #129
Phat Steve's Avatar
That frigin noise was drivin me crazy i moved the strikers in and the noise would go away and come back makin me even more crazy. Today I moved the drivers door striker down about 2mm and the noise has not come back yet. I will keep you guys updated.
Old Mar 3, 2008 | 07:28 PM
  #130
Coastie's Avatar
Originally Posted by DBB888
SEE POST #46 for Solution
OK Guys
Going over small bumps or just normal driving I hear as sqeaky noise coming from the seat belt adjustment area. Its right at my left ear. Mike
I had a similar problem. When I would go over larger bumps or rocks I would get an annoying squeak near my right ear. Left her home next time and the squeak was fixed.
