any one have problems with their top leaking when it rains???
Old May 4, 2010 | 04:01 AM
Venus-JK's Avatar
Default any one have problems with their top leaking when it rains???
it has been raining here since yesterday morning, when i got off work and went to get in my jk there was water all over my driver seat. my top seems to be leaking through the side (up at the top of the door) but its not just leaking on the drivers side....its leaking in the same spot on the passenger side as well.....idk if its not put on right or what.....any suggestions on what might be wrong?
Old May 4, 2010 | 04:03 AM
dlincoln91's Avatar
my hardtop has no leekage but my soofttop leaks all the time...
welcome to a jeep
Old May 4, 2010 | 04:06 AM
frankie945's Avatar
same here..
Old May 4, 2010 | 04:07 AM
Venus-JK's Avatar
thats lame.....i really dont like my butt getting wet.....
Old May 4, 2010 | 04:10 AM
blockrockin's Avatar
yes seems like a common problem.. their are tons of post here about it... and lots of suggestions that may help
Old May 4, 2010 | 04:13 AM
Venus-JK's Avatar
yeah well im not too tech savy on this thing yet....so i have no idea how to navigate around it....
Old May 4, 2010 | 04:31 AM
Rhino64's Avatar
This is my third Jeep two soft tops both soft tops had leaks. I just dealt with them. The JK has the hard top and so far no leaks. I've also owned a convertible car it leaked too. None of the leaks were major but they were still leaks, I think its just one of those things that happen with a rag top.
Old May 4, 2010 | 06:10 AM
JRM261's Avatar
My soft top never leaks but the freedom top leaks all the time. My freedom top leaks through the screws in the soundbar and up front above the radio. If it's your hardtop, someone on here told me to by some NAPA Sil-glyd and put it around all the seals which actually worked. Which top are you running that's cause the leak?
Old May 4, 2010 | 06:39 AM
wolfpuppies3's Avatar
Default Which top to you have?
My soft top on my 2009 JK 2dr leaked around the headliner, the water would follow the windshield around and ended up soaking the driver's side carpet. Nowhere else.
My newly installed Freedom hardtop leaks not one drop. Jeep has a 148 page leak repair manual available for down load that addresses the various sources and cures for the leaks that most of us witness at least sometime with either the soft or the hard or both tops.
Old May 4, 2010 | 06:47 AM
2007JKX's Avatar
Same problem. When it rains hard my driver side floor board gets soaked. Last week it rained really hard and my driver side seat was soaked.
The irony is that I have a cheap off-brand soft top on my '03 TJ and it never leaks.
