Anyone have these probs with their JK??
Old Mar 7, 2010 | 07:47 PM
  #21
HAVOC625's Avatar
No problems here.........atleast not yet
Old Mar 8, 2010 | 03:22 AM
  #22
KINGBILL's Avatar
Had problem with my 08 Unlimited with carpets getting wet.
1. Header seal was leaking down A pillar behind plastic coverings and behind dash.
2. Door seals at bottom edge where it meets sill plate would let water in an soak carpets.
Jeep changed door and header seals. So far so good.
Old Mar 8, 2010 | 04:05 AM
  #23
TMC's Avatar
TMC
I have an 07 2 dr and had very simmilar problems. For me it ended up being a leak somewere by my windshieldwiper and ran down behind my dash. after they fixed it, it has been about 2 yrs since and no problems
Old Mar 12, 2010 | 04:02 PM
  #24
wazooz2424's Avatar
we have the surface rust on the seat frames, but water leaks. the rust is on the hinges of the seat where the back meets the bottom.
Old Mar 12, 2010 | 04:26 PM
  #25
MacJeepMaster's Avatar
I have the same problem. What I did was just start hanging "DampRid" the kind you hang in closets to remove moisture and it seems to work. I'm gonna check the plugs this weekend and I'll have to keep checking as it will go back to the dealer for a fix if it is actually there.
Old May 9, 2010 | 06:03 AM
  #26
DANIMAL's Avatar
I just picked up my 07 Unlimited Rubicon several weeks ago, and found my front carpets wet the other day when it rained. I took out the carpets to check the plugs...they seemed fine. Now that I found this info from you guys, I know what else to look for.
I am new to this forum, but not new to Jeep/4x4 forums. I will be spending a little more time here.
Thanks for the info,
Dan
