Automatic Door Locks
Old Sep 22, 2007 | 01:56 PM
  #51
cjsdad's Avatar
Great thread!! I have disabled the seatbelt chime, p/l unlock when front doors open, and key fob unlocks all doors with first press of the unlock button.
Old Sep 22, 2007 | 06:18 PM
  #52
venom's Avatar
Originally Posted by FireMedicXL
Figured out the DIY method.
- shut the doors and turn the key from "off" to "on" (stop turning the key at the point just before the engine starts). Do this five times. On the fifth time the key should be in the "on" position, push up on the power door lock.
I'm pretty sure this is what I did. All I know is that now when I open the drivers door, all 4 doors unlock. Good luck. It would be nice if there was a chime telling you the code has changed. You won't know if it worked until you go for a drive.
Actually, watch your odometer
after the 5th key turn it goes to all bars to tell you it's in program mode and when you do the door lock button when it "takes" the odometer says 'done'
Old Sep 23, 2007 | 05:41 AM
  #53
1963Duo's Avatar
Default All the truth from the service manual (long)
Just found from a friend (who has the service manual) all about power locks. This is a copy paste:
OPERATION
POWER LOCKS
All doors can be locked or unlocked mechanically and independently with their respective locking knobs. The front doors can also be unlocked by actuation of the inside remote door handle.
CENTRAL LOCKING/UNLOCKING (IF EQUIPPED)
The door locks can be locked or unlocked electrically via the exterior door key cylinders to provide the central locking/unlocking feature. The central locking/unlocking feature incorporates a customer programmable "Double activation unlock" feature which operates in the following manner: When enabled, the first turn of the key cylinder to the UNLOCK position (toward the front of the vehicle) will mechanically unlock the door whose key cylinder is being turned. A second turn of the key cylinder to the UNLOCK position (within five seconds of the first turn) will cause all vehicle doors and liftgate to unlock electrically. When this feature is disabled, all vehicle doors and liftgate will be unlocked electrically upon the first turn of a key cylinder to the UNLOCK position. The vehicle is locked electrically by turning the key cylinder to the LOCK position once, regardless of the state of the double activation unlock feature.
REMOTE KEYLESS ENTRY
The transmitter has three buttons for operation: LOCK, UNLOCK and PANIC.
Pressing the UNLOCK button will unlock the driver side door, flash the park lamps twice and enable illuminated entry. Pressing and releasing the button once will unlock the driver side door. Pressing and releasing the button two times within a five second interval will unlock all doors.
Pressing the LOCK button will cause the horn to sound a short chirp (if enabled) and flash the park lamps to notify that the all door lock signal was received and set. Illuminated entry is cancelled and the interior lamps are faded to off.
Pressing the PANIC button will cause the panic alarm to sound for three minutes, until the PANIC button is pressed a second time, or the vehicle reaches a speed of 25.7 Km/h (15 mph). The receiver is capable of retaining a Vehicle Access Code (VAC) even when power is removed. Each Remote Keyless Entry (RKE) module must have at least one and no more than four transmitters.
ROLLING DOOR LOCKS
When the rolling door lock system is enabled, the RKE module will automatically lock all the vehicle doors and liftgate when all of the following conditions are met:
All doors are closed
The vehicle speed exceeds 25.7 Km/h (15 1 mph).
The throttle position sensor tip-in is greater than 10 2 degrees.
The RKE module will automatically re-lock all doors if the above conditions are met and if any of the doors become ajar and then closed again.
The enabling/disabling of the rolling door lock feature is customer programmable, as well as programmable with the scan tool.
The power lock motors are also equipped with a thermal protection system which prevents the motors from burning out. The motors may chatter if they are continuously activated
STANDARD PROCEDURE - DOUBLE ACTIVATION UNLOCK
The toggling of the double activation unlock feature (between enabled and disabled) can be performed with the use of the scan tool, or by the customer.
SCAN TOOL PROGRAMMING
When using the scan tool, select:
1. “CCN”
2. “Miscellaneous Functions” and then the desired function.
CUSTOMER PROGRAMMING
1. Open the driver door, sit in the driver seat, and close the driver door.
2. Turn the ignition switch to the RUN position (without starting the vehicle) and then back to OFF. Repeat this step three additional times (for a total of four key ON/OFF cycles).
3. Within 10 seconds of switching the ignition switch to the OFF position for the last time (at the end of the fourth cycle in the above step), press the driver interior door lock switch to UNLOCK.
4. A single chime will be heard to verify that the customer programmable toggle of the double activation unlock was successfully completed.
Steps 2 and 3 must be completed within 10 seconds.
NOTE: When toggling the double activation unlock feature (customer programmable), the toggle that happens will be from the last state of the double activation unlock. If the double activation unlock feature was enabled, after the toggle process, it will now be disabled and vice versa. There is no telltale to inform you of which state the double activation unlock feature is in.
STANDARD PROCEDURE - ROLLING DOOR LOCKS
The toggling of the rolling door lock feature (between enabled and disabled) can be performed with the use of the scan tool or by the customer.
1. “Theft Alarm”
2. “VTSS”
3. “Miscellaneous” and then the desired function.
3. Within 10 seconds of switching the ignition switch to the OFF position for the last time (at the end of the fourth cycle in the above step), press the driver interior door lock switch to LOCK.
4. A single chime will be heard to verify that the customer programmable toggle of the rolling door locks was successfully completed.
NOTE: When toggling the rolling door locks (customer programmable), the toggle that happens will be from the last state of the rolling door locks. If the rolling door locks were enabled, after the toggle process, they will now be disabled and vice versa. There is no telltale to inform you of which state the rolling door locks are in.
Old Sep 23, 2007 | 04:26 PM
  #54
bluer101's Avatar
OPERATION
POWER LOCKS
ROLLING DOOR LOCKS
1. “CCN”
1. “Theft Alarm”
2. “VTSS”
Thanks, I will have to try the rolling auto lock whe I get a chance, I hate that feature.
Also do you have the instuctions on how to disable the headlights from coming on when unlocking with the keyless entry?
Old Sep 24, 2007 | 01:50 AM
  #55
1963Duo's Avatar
I am sorry i don t have this info,I ll check if i can find it and post it in this thread.
Old Dec 2, 2007 | 11:21 AM
  #56
natius's Avatar
Default There is a God
I am a new man. No chiming for a 2 block run to the gas station now and all of my doors unlock when i get out. Praise Jesus or Buddah or whomever you will, because my JK has been reborn!
Only now if I open my door while driving over 15 MPH and remove my seatbelt, the ESP kicks in and the horn sounds. Only kidding. Please don't try that at home.
Old Dec 2, 2007 | 11:32 AM
  #57
ckarate2's Avatar
Originally Posted by bradfridell
Speaking of disabling things, anybody know of a way to disable the seat belt chiming? Again, I'm all for safety, but I don't need that incesent chiming to remind me to put my seat belt on.
turn the key on and plug and unplug the seatbelt 3 time in 10 sec. with the final position the seatbelt unlatched will turn of the seat belt minder.
Old Mar 12, 2008 | 08:23 AM
  #58
jetsfan28's Avatar
OK, I am bringing this one back to life. I want to see what recent experience has been.
Last week, all of a sudden, my "unlock all with driver door open" stopped working. No idea why. The autolock at 15MPH still worked fine. Any thoughts on this?
I've read ALL the posts on this topic. Has anyone figured out what the actual proceedure is to reprogram this? The excerpt above didn't work exactly. In my case, I had to cycle the key just three times to get the "--------", then push up on the drivers door lock (unlock) two times, holding it for about a second each time. The the ODO read "dOnE" and the all unlock features were back.
I only figured this out in an empty parking lot with trial and error (how many key cycles, push up, push down, once, twice, etc....). The 15MPH feature works and now so does the all unlock feature.
Has anyone else gone through this and determined the actual proceedure. Did I just get lucky?
Old Mar 13, 2008 | 04:14 AM
  #59
TurkeyFreer's Avatar
Default Seatbelt chime
Seatbelt chime procedure listed in this thread:
I did this procedure yesterday as I was leaving work and VIOLA! No more annoying seatbelt chime - thanks for posting this!
Old Mar 13, 2008 | 07:14 AM
  #60
bOLsAK=3's Avatar
Just take a look at the dates on this thread. This thing has been up for a while and actually, come to think, this is the thread that got me hooked to this site. I think one of my first posts is one here. This thread needs to be archived IMO. It's very-very useful.
