Axle shaft guides
*I live in OKC, he now lives in Helena, MT.
Ray, preparing to cross the Mackenzie River in Yukon, Canada (north of the Arctic Circle) ...
You can get them if you want, but as I noted in your other thread, the sole purpose is to hold that end of the axle shaft up semi-aligned with the hole in the seal you have to slide it through, and they really don't do a superb job at that IMO. Other than that, they sit on the shaft and spin around within the air in the tube once everything is installed. Half the time they bend and deform and are worthless anyhow. The $12 would be better spent on a 12-pack of beer.
Well, it's certainly a leaking axle seal. The guides are simply plastic ring on the shaft that "helps" align the shaft in the axle tube as you're sliding it in. I say "helps" cuz it still don't get it perfectly aligned with the axle seal the shaft has to slide through. It is possible to get an axle shaft through the axle seal as well without those guides if you're careful. It's the passenger side that is a little harder cuz the length of the shaft.
Remember folks those guides also keep the end of the axle out of the inside tube grit and keep the seal clean as they guide the axle through by keeping the end of the axle off the dirt. The guides worked perfectly on mine when installing axles back into old seals and still no leaks.
