Break squeal
Old Mar 8, 2008 | 05:40 PM
Gunny's Avatar
Originally Posted by CIJeep
That should be easy to find the cause of when jacked up, play checked, then wheel pulled and the rest inspected. If you don't do it yourself there isn't much point in asking about it. I can see a couple variables that would cause it.
No lateral run out on the wheel so that eliminates wheel bearings there isn't any play top to bottom so that rules out ball joints. I'm an ASE mechanic but I'll let the dealer figure it out on their dime.
Old Mar 8, 2008 | 05:42 PM
Gunny's Avatar
Originally Posted by TripleJeep_99
Sounds to me could be a caliper issue either a piston(s) are hooped or the caliper is not sitting correct.
It only happens during right hand turns under power so I'm thinking something is warping or flexing for lack of a better term.
Old Mar 8, 2008 | 10:28 PM
CIJeep's Avatar
Thats cool, but then why did you ask us about it?
Please post what the outcome was when resolved. I have an idea, but without pics or my own visual inspection it would be very hard to do anything but guess.
Old Mar 13, 2008 | 06:28 AM
Gunny's Avatar
I picked it up from the dealer and it turns out that the top bolt that holds the hub to the steering knuckle was missing and the other two were loose. They replaced the rotor and pads again was well as replacing and torquing the hub bolts. So all is well.
