A/C Blower Motor Not Working
Old Oct 17, 2019 | 12:04 PM
brent372's Avatar
@Spoonduke714
Thanks for this tip. This just happened to me. I will check this before buying any parts.
Old Jun 29, 2020 | 10:00 AM
Spoonduke714's Avatar
Same issue again. Cleaning the switch didn't work this time. Any additional thoughts?
Old Jun 29, 2020 | 03:22 PM
cybersonarbat's Avatar
Default A/C Blower Motor Not Working
You're on the right track. The power to the blower motor is switched on the neutral (ground) side by the dash control unit. It's not difficult to change and cheaper than going to the stealership. The other thing involved is, as another reader has mentioned, is the request over can bus.
This implicates the PCM and the price goes up. As the other reader points out, the stealer ship can probably read this.
Good luck.
Old Feb 2, 2022 | 10:17 AM
fyrfytr144's Avatar
The original question was "where is the blower motor resistor", you mentioned you replaced yours, where was it located?
Old Jul 6, 2022 | 06:38 PM
cassandra.bock@icloud.com's Avatar
Where is the resistor located?
Old Jul 21, 2023 | 01:07 PM
Pr617's Avatar
Originally Posted by Cain1970
My HVAC blower motor completely stopped working on my 2008 JK X. This begin a couple of weeks ago out of the blue. I've been trying to repair this for the past week. With help from this forum I've replaced the blower motor, resistor, and relay, but the motor still does not operate.
Below is a list of things I've tried:
- I've ran 12V directly to the blower motor and the motor runs.
- I've confirmed with a voltmeter that the blower motor receives 12V from the plug when the fan switch is on. When the fan switch is off the plug yields zero volts. (Puzzling tho that the voltage does not change at the plug whether the switch setting is on low or high.)
- I have reset the system by disconnecting the battery for ten minutes.
- I have wiggled every wire I can think of with the system on at the time.
- At one point I had replaced the blower motor but not the relay or resistor. I went to the auto parts store. They handed me a new relay. I plugged it in and turned the key. The blower worked in all settings. I thought it was repaired so I went back in the store and paid for the relay. I went back out to the car and the blower has not worked since. That's when I ordered a new resistor and replaced it.
Any ideas? How do I check the blower switch?
Thanks in advance.
Where is the locaiton of the relay that you changed? What fuse box or other location is it in? Thank you very much in advance.
