Check Engine Code Cylinder 6 Missfire
Old Apr 17, 2014 | 12:40 PM
GreencrawlerJK's Avatar
Default Check Engine Code Cylinder 6 Missfire
Hey y'all
I had a check engine light about a month ago and I just got another one, both read cylinder 6 Missfire. I don't think anything is wrong, the Jeep doesn't make any funny noises or stutter or anything, idles just fine. I cleared the code the first time,
It went away, and it just came back. The Jeep drives fine. I cleared the code again. Should I be worried? Should I have it checked? Or is the sensor malfunctioning? If the cylinder was misfiring, would I know it? Would it make a sound or would I feel it! Please help! I have a 2012 JKU with the 3.6 Pentastar
Old Apr 17, 2014 | 01:53 PM
cwewasson's Avatar
Veteran: Navy
Originally Posted by GreencrawlerJK
Hey y'all
I would do a search on here about replacing the left head. Seen more then a few write up about. I've lucked out so far. But looks like yours ran out
Old Apr 17, 2014 | 06:32 PM
egeli's Avatar
Take it to the dealer it needs a left cylinder head. It may run fine now but soon or later the valve seat might fall out causing more damage.
Old Apr 17, 2014 | 08:03 PM
Mr.Bones's Avatar
Yup bad head. Need to get it replaced. Mine went out at 15000. My mpg was around 13 and after the head replacement I am getting 19. As long as you have a misfire code you won't have an issue getting it done. Just repeat after me... "Poor fuel mileage, rough idle, and miss fire code". Those are the magic words :-)
Old Apr 18, 2014 | 07:03 AM
cwewasson's Avatar
Veteran: Navy
Got the rough idle and low mpg but no code yet.
Old Apr 19, 2014 | 02:26 PM
Tomasito's Avatar
Mine sounded funny since 4-5000 km.. The check engine light never came on until 50000km.
Old Apr 21, 2014 | 07:15 PM
2climbbig's Avatar
I had the same issue same cylinder as well. It was my coil. THey are cheap to buy, I paid $25 I think.
There are 6 individual coils within the coil box. Its held on by 3 or 4 philip screws. Very easy to do. Just take a picture and mark your cables.
Old May 21, 2014 | 06:00 PM
valovic's Avatar
Default Cylinder misfire on no.4
I just got a check engine light at 34750 mi. Took it to the dealer and mentioned the engine light. They called me back and it needs a new head.
I had no rough idle, and gas mileage was at 19. Would not have known it was an issue if the light did not come on.
Old May 21, 2014 | 06:03 PM
valovic's Avatar
You don't have the Pentastar engine so you would not have the same issue with the valves.
Old May 21, 2014 | 06:49 PM
jeepmojo's Avatar
Default mines ticked from the time i got it
23,000 miles no code has a slight sputter but they wont fix it till it codes out so I keep driving it
wish they would just recall the dam things seems every 12 goes at some point why not just fix it before it does damage , No they let you have to drive a new jeep that sounds like shit for years before it throws the code
