View Poll Results: Has your Jeep had/have clunking or knocking in the steering?
Yes, I have had it and still have it.
102
64.15%
Yes I had it but its gone now
17
10.69%
No, I have never had it
40
25.16%
Voters: 159. You may not vote on this poll
Clunky/Knocking Steering Poll
Old Jun 15, 2009 | 04:31 PM
  #21
c90dan
Guest
Posts: n/a
Notice for the first time yesterday. Stuck in stop and go traffic for an hour and a half. I checked out the bushing on the shaft, [that doesn't sound right] ,but it had not moved. May take it to the dealer, for all the good it will probably do.
Old Jun 15, 2009 | 04:41 PM
  #22
rubimonster's Avatar
Mine does it. I stuck a grease needle in the shaft boot and shot some grease in last summer b4 a long road trip and it went away. Now it's back and anoying as ever guess I'll re-grease.
Old Jun 15, 2009 | 04:53 PM
  #23
Hellbound13's Avatar
Originally Posted by JKRINGO
Lucky for me I don't know what the hell you all are talkin about!
Chances are you will at some point.
Old Jun 16, 2009 | 02:32 AM
  #24
Mk-Dubai's Avatar
comes and goes on occasion
Old Mar 4, 2011 | 04:50 PM
  #25
reddragon's Avatar
Does anyone know if there is a TSB fix for this knock?
Old Mar 4, 2011 | 07:10 PM
  #26
RA032726's Avatar
Banned Member
Never a clunck or knock in 19K+.
Here is a 40+ page thread discussing a few possible fixes:
https://www.jk-forum.com/forums/show...teering-people
Old Mar 4, 2011 | 10:14 PM
  #27
JKlad's Avatar
Had my clunk "fixed" by the dealer (they replaced the "steering shaft ball-support" apparantly) and it came back about 3K miles later. Will wait until warranty is just about up, get them to replace the intermediate shaft and then do the 5th wheel grease mod that many here have tried and found successful.
Old Mar 14, 2011 | 02:04 PM
  #28
spyther's Avatar
What an incredibly annoying problem is. 2 out of the 3 JKs I've owned have had it, especially in warm weather. The third had stock death wobble. The worst part is both problems were ones the dealer couldn't "reproduce"
Old Mar 14, 2011 | 02:32 PM
  #29
This is a pretty easy fix.
Just make a small cut in the rubber boot on the steering shaft, & spray grease on the splines on the steering shaft. (black rubber accordian style boot on steering shaft, drivers side of motor.) The splines don't seem to be lubed properly at the factory & when you turn the steering wheel, they kinda stick & make a clunking, knocking sound.
I used a can of white lithium grease with teflon, inserted the hose into the small slit I made in the boot, filled the boot with grease & viola. No more clunk/knock.
My '10 Rubi Unlimited did this when new & at around 500 miles & did the lube trick & all is still well, now approaching 18k.
BTW the clunk I am referring to is the one commonly found on new JK's when you turn the steering wheel, not to be confused with the worn out ball joint clunk which is more common on higher mileage JK's
Hope this helps.
Old Mar 14, 2011 | 03:05 PM
  #30
Welcome to the nightmare front end on the JK.
