View Poll Results: Has your Jeep had/have clunking or knocking in the steering?
Yes, I have had it and still have it.
102
64.15%
Yes I had it but its gone now
17
10.69%
No, I have never had it
40
25.16%
Voters: 159. You may not vote on this poll
Clunky/Knocking Steering Poll
In the warn weather or even in the cold weather after a while of driving (allowing the bay to heat up) my clunk comes. This is typical of the intermediate shaft. When it's very warm it can get pretty bad, I will also feel it in the brake and gas pedal sometimes. Like a slight knock in the pedal at the same time as the knock in the steering wheel
I've read this is very common among people having the steering clunk, but seeing as how my knowledge of the front end is lacking, can someone explain to me how the pedals can be affected too?
Also, what are symptoms of worn balljoints as opposed to the intermediate shaft problem?
Originally Posted by Smopho
The same subassembly that the pedals pivot on is also used to support the steering column where it goes through the firewall. I knock on the column or shaft will be felt through the pedals.
Originally Posted by Uneasy Rider
You've tried spraying/pumping grease in the rubber boot on the steering shaft & you still have the steering clunk?
That sucks. I wheel my jk often pretty hard and never had a steering box issue at all.. its surprising how many ppl have problems though.
