code reset with key sequence?
Old Aug 16, 2013 | 06:30 AM
jk144's Avatar
Default code reset with key sequence?
I have a 2009 Wrangler Unlimited Sahara. The check engine light is on. I used the key sequence method and observed code P0300 at the odometer. Is there a key sequence method similar to displaying the codes that will clear the codes?
I know that AutoZone will let customers use the AutoZone scanner to clear codes. I know that disconnecting the battery will clear codes and result in a computer relearn.
The P0300 code is difficult to diagnose since it is a random misfire detection.
About 7 months ago I noticed excessive oil consumption (2 quarts in 900 miles). The dealer replaced the rings. My jeep had 55000 miles at the ring replacement.
I have put about 2700 miles on the Jeep since the rings where replaced. I suspect that the excessive oil consumption may have fouled the plugs causing the P0300 code.
Until I get the P0300 cause determined I would like to reset the code in my garage without disconnecting the battery and without buying a scanner. If a key sequence code reset method is not possible please let me know. I plan to use a fuel additive to clean the injectors, plugs and valves then reset the code and see if it reappears. I also plan to visit the dealer for their opinion.
If a key sequence code reset method is not possible then I will buy a scanner.
Thanks for your help.
jk144
Old Aug 16, 2013 | 06:36 AM
2012JKJeep's Avatar
jk144
I don't believe that you can reset the code through a key sequence. You may be able to pull a fuse (In the Neon we use to pull the fuel pump fuse and that reset the computer) and have the computer reset.
A cheap scanner is a good idea anyway. I've got a number of bluetooth ones that I use with my vehicles as well as friends. (Old Bluetooth Android or iOS phones work great in conjunction with the scanner.)
I've seen bluetooth scanners for as little as $15-25 online.
Old Aug 16, 2013 | 09:38 AM
TheRover's Avatar
Million dollar idea for some one!! Create a smart phone app that is a Bluetooth scanner!!
Old Aug 16, 2013 | 09:44 AM
oleskool's Avatar
It's called Torque. Works great
Old Aug 16, 2013 | 09:49 AM
JKphotoshoot's Avatar
Yep, torque is awesome. Can keep a eye on temps and reset codes.
Most programmers let you reset also.
Old Aug 16, 2013 | 01:51 PM
NVW-SSV's Avatar
So does the Torque paid version now display transmission temp?
Old Aug 16, 2013 | 03:55 PM
It's in the paid version but you have to create 2 new PID's in settings.
Old Aug 16, 2013 | 04:30 PM
NVW-SSV's Avatar
Thank you sir. OK to PM you to get help setting that up?
Old Aug 16, 2013 | 04:32 PM
Sure, was actually loading up some pics of screen.
Old Aug 16, 2013 | 06:15 PM
My12redrubi's Avatar
Does the torque scanner work with iPhone? I was reading one of the descriptions on eBay and it read not compatible with apple products. Just wondering if it meant the computer software. Thanks
