Diff. Fluid Change Question
Old Nov 4, 2009 | 07:59 AM
saltman's Avatar
ronjenx is saying they fill with the 80/90 not the 75/140 from the factory. If that is true. It is not a factory synth fill.
I seem to remember it was different before. Could be wrong. You can check the tags on your difs. Pretty sure my 07 said 75/140 on it and they changed mid 07 or 08.
Old Nov 4, 2009 | 08:00 AM
racer83l's Avatar
mine came with tow package from the factory and SHOULD have been filled with the 75-140. I use it all around since Im running 35's
Old Nov 4, 2009 | 08:01 AM
saltman's Avatar
ahhh... that makes sense. towing package might be the key. I also use the 75/140. Royal Purple.
Old Nov 4, 2009 | 08:18 AM
Hellbound13's Avatar
I bought the 75w 90 mobil 1, I have no tow package am I okay to use that?
Old Nov 4, 2009 | 08:53 AM
ronjenx's Avatar
Yes.
Old Nov 4, 2009 | 09:00 AM
ronjenx's Avatar
Originally Posted by ronjenx
Two people in this thread have said the original stuff in the diffs is synthetic. Could be, but I would have to see the bottle to believe it.
The MOPAR stuff is synthetic only if it says "synthetic" on the bottle.
Initially, they come with Mopart Gear & Axle Lubricant (SAE 80W-90) (API GL-5), which is a general purpose GL-5 gear oil. I don't believe it says synthetic on those bottles.
Originally Posted by racer83l
here you go.
Thanks for verifying what I posted. I looked for a pic, but couldn't find one.
The Mopar Gear & Axle Lubricant (SAE 80W-90) (API GL-5), doesn't say synthetic on the bottle. Got a pic of that?
Old Nov 4, 2009 | 09:24 AM
saltman's Avatar
Mopar 80/90 is not synth.
ronjenx - are you suggesting they put 80/90 in the difs with the tow package?
Old Nov 4, 2009 | 12:33 PM
ronjenx's Avatar
No. I made no mention of tow package. I have no idea if the tow package would include the recommended synthetic rear diff oil from the factory.
I was just saying one cannot assume the oil from the factory, or all bottles of the MOPAR stuff, are synthetic, unless it says so on the bottle..
Old Nov 8, 2009 | 11:27 AM
dmwil's Avatar
Does the Rubicon (locking rear diff) require Limited Slip Diff additive?
I'm getting ready to fill it with Supertech 75W-140 synthetic gear oil, and just need to know if I need to use the additive or not.
Thanks!
Old Nov 8, 2009 | 12:12 PM
ronjenx's Avatar
I'm getting ready to fill it with Supertech 75W-90 synthetic gear oil, and just need to know if I need to use the additive or not.
Thanks!
Originally Posted by rickc309
I looked at my Mobile 1 diff fluid bottle, it says LS right on it. No addition additive needed.
The JK Rubicon diff is a locker, not a limited slip. Therefore, no additive is required.
You are correct, though, about the Mobil 1. If you had a limited slip, and were using the Mobil 1 stuff, you would not need the additive.
