diff oil question
Old Jan 15, 2014 | 03:00 PM
Grin-n-Barrett's Avatar
Default diff oil question
So I changed the oil in my diffs, but didn't get a good seal on the rear diff. By not good I mean I check it and see it has a drip or so always coming from the bottom. (Not dripping or anything, but a droplet hanging from the middle of the diff).Still full when i check it but, I feel this is unacceptable, but no biggie it was my first time ever doing diffs, so eh. Anyway I have only driven to work a few times so maybe 50 miles? Roughly since I did them. Is it ok to just clean the cover really well, pull the drain plug and catch it in the oil bottles I used so i don't have to buy more amsoil?
Old Jan 15, 2014 | 03:24 PM
Croce's Avatar
If you just put new oil in i dont see any reason why you cant re-use it. I highly suggesting using a lubelocker instead of using RTV sealant next time, much easier to install and can be used several times
Old Jan 15, 2014 | 04:07 PM
OH9JK's Avatar
JK-Forum Ambassador
Just so you know the diff covers dont have to be removed to change the oil...only if you want to inspect the gear set. There is a drain plug on the bottom of the housing.
Old Jan 15, 2014 | 06:33 PM
Yes I know. I had 4:10 gears installed and just went through the break in mileage on them and wanted to take apart to clean well and to inspect how they did.
Old Jan 15, 2014 | 06:41 PM
nbdude's Avatar
+1 on re-using the same oil. Just did mine but didn't pull the cover. Still cant believe the dealer wanted $129.95 per axle to do this. Took me an hour and $40 of gear oil.
